Goon Diff Oil
Goon Diff Oil
Postby datzenmike » 25 Oct 2011 19:49
It's been brought to my attention that the gear oil for the sedan is GL-5 while the wagon H-190 is GL-4 same as the transmission. Can anyone confirm this from a Nissan FSM or factory statement. Something official and not from a Haynes or Chiltons. Does it say GL-4???
jason
Re: Goon Diff Oil
Postby jason » 25 Oct 2011 20:16
My 1973 Nissan 1600 manual seems to reference the sedan only, gl4 in the tranny and steering, gl5 in the diff. Perhaps someone else has the wagon one?
510-Trevor
Re: Goon Diff Oil
Postby 510-Trevor » 25 Oct 2011 20:18
The 1972 FSM shows GL-5 for both. There is an extra note for the wagon diff carrier to use SAE MP 140 gear oil when temp is over 32 degrees C (90F)
1972 Yellow 4dr - 1972 Red 2dr
Re: Goon Diff Oil
Postby datzenmike » 26 Oct 2011 06:29
Did all the wagon diff come with the aluminum carrier?
GL-4 is usually used in the transmission and contains less sulphur anti scuff additives to protect the brass synchros. Usually GL-5 is used in the rear ends only and needs these additives. I'll wait and see if anyone else has heard of the GL-4 in the diff.
510-Trevor
Re: Goon Diff Oil
Postby 510-Trevor » 26 Oct 2011 09:02
On page PD-19 of my 1972 FSM it lists the info I posted above. It also notes the that the carrier is made of a light and strong alloy of aluminum.
In the General Info section on page GI-12 it notes GL-4 for the T/M Gear Oil and GL-5 for the Diff Gear Oil.
Re: Goon Diff Oil
Postby datzenmike » 26 Oct 2011 20:37
OK here's why I ask. GL-4 is recomended for transmissions that have 'yellow metal' of copper/bronze synchros. Perhaps an earlier goon H-190 had brass in it so I checked.
This the the internals from an early 320 H-190
This is the internals from an unknown year 510 goon H-190
Looks like there may be some bronze or copper in it. I believe it's a thrust washer on the pinion gears. I have always recommended GL-5 for Nissan rear ends and this may be wrong. What do you think?
Re: Goon Diff Oil
Postby Byron510 » 26 Oct 2011 20:59
I'm not sure on the oil suggestions, but yes all PL510 H190 wagon diffs had the aluminum carrier 68-72.
Re: Goon Diff Oil
Postby datzenmike » 26 Oct 2011 21:31
So did the 520/521 and early 620.
Well I checked some part numbers and the goon thrust washers were used on all H-190 after the 521 and also includes the Roadster. So I don't know. Maybe false info.
