SR20DET "Black-Top" Engine Overhaul Gasket P/N's
Postby RWD_NissanMan » 25 Nov 2004 12:45
This is the Parts List for the individual items that make up the engine rebuild gasket set for the S14 "Black-top" VVT (Variable Valve Timing) if anyone needs it (taken from the packing list inside the kit I got).
10101-69F25 (SR20DET) Gasket Kit - Engine Repair
Part# Description Qty.
KP710-00150 Gasket sealant - F.I.P. (150g.) Qty. 1
11026-01M02 Washer - drain plug Qty. 1
11044-65F03 Gasket - cylinder head Qty. 1
12279-18V00 Oil seal - crankshaft rear Qty. 1
13079-2J200 Gasket - chain tensioner Qty. 1
13207-D0111 Oil seal - valve exhaust Qty. 8
13207-84A00 Oil seal - valve intake Qty. 8
13270-65F00 Gasket - rocker cover Qty. 1
13271-65F00 Gasket - rocker cover Qty. 1
13510-53J10 Oil seal - crankshaft front Qty. 1
14032-65F00 Gasket - collector intake Qty. 1
14035-78J01 Gasket - intake manifold Qty. 1
14036-53J00 Gasket - exhaust manifold Qty. 1
14415-17M00 Gasket - turbo charger inlet Qty. 1
14445-79E00 Gasket - turbo charger outlet Qty. 1
14465-79E00 Gasket - inlet tube air Qty. 1
15053-1E400 O ring - oil strainer Qty. 1
15066-0M300 Gasket - oil filter bracket Qty. 2
15066-77A00 O ring - seal Qty. 1
15189-40P00 Gasket - eye bolt Qty. 2
15189-69F01 Gasket - eye bolt Qty. 4
15196-69F00 Gasket - oil tube outlet Qty. 1
15270-D0103 Gasket - oil filler cap Qty. 1
16175-65F00 Gasket - throttle chamber Qty. 1
16618-10V05 O ring - injector upper Qty. 4
16618-10V10 O ring - seal Qty. 1
16618-53J00 O ring - injector lower Qty. 4
22131-50F00 O ring - support distributor Qty. 1
23785-54C00 Gasket - A.A.C. valve Qty. 1
23785-65F00 Gasket - A.A.C. valve Qty. 1
RE: SR20DET "Black-Top" Engine Overhaul Gasket P/N
Postby heirfaus » 24 Jan 2007 19:02
I don't know if you guys found a reliable source for ALL your SR parts needs, but I was reading the premier issure of Project Car and found an article for a 240sx SR swap. Anyway they listed a dealership and the article says "they stock more OEM SR parts than we know what to do with, not to mention all the aftermarket stuff." And they are talking about the actual JDM parts, not the US SR version parts. Just a heads up so you guys don't rack your brains looking for stuff.
Oh and they are in Puente Hills, wherever that is :?
oh yeah it's called Superior Nissan
Corky Bell, Maximum Boost
Re: SR20DET "Black-Top" Engine Overhaul Gasket P/N's
Postby fryanbacon » 03 Apr 2008 07:01
another good source for oem/jdm nissan stuff is West Covina Nissan in SoCal. They sell a lot of SR20 parts on their website and on ebay. I'm buying my full gasket set from them OEM new (including everything on the list here) for $160 shipped. I think that's pretty good.
