Jammin a 510 full o ponies
foamy
Post by foamy » 14 Dec 2005 15:34
Hey guys
I am on a major hunt for ANY articles, pictures, web sites etc. for a small block Ford swap on a 510. Anything at all would be greatly appreciated, as I have found absolutely nothing.
Thanx
Gensaiken1
RE: Jammin a 510 full o ponies
Post by Gensaiken1 » 14 Dec 2005 17:30
All I know is that it has been done before. But it usually a very rare swap. All I could recomend is going to the dime quarterly and subscribing to the mailing list and posting this question there. A very wide range of extremely knowlegable 510 owners there. They would most likely be able to point you some where.
1971 2dr Datsun 510 - L20b, 219 SSS Head, Roundtop SU's
frenched510
Post by frenched510 » 14 Dec 2005 19:14
I hope its gunna be a drag car cuz I dont think it'll handle nearly as good. I've seen a ford racing crate 350 motor in a 510. He cut out the firewall and the tranny tunnel and made a custom crossmember. And another thing is the diff might not handle the torque. Thats what'll kill the diff is the torque. This guy also swapped a corvette rearend which is pretty cool but I dunno how he managed that.
Post by icehouse » 14 Dec 2005 20:52
Why not do an sr? Or another 4 cylender turbo, then it would be fast and still handle, but the r200 would hold up the the power. 510' are about the worste rear wheel drive drag car there is. Your going to need a bigger gas tank to. That's one compaint I heard about the v8 conversion's. You should put the v8 in a pinto and save the 510 for a more worthy project.
shwyn510
Post by shwyn510 » 14 Dec 2005 21:16
^^^agreed, but to each his own. i really don't see any positives of a V8 swap, but if thats what you want, go for it. it's a really rare swap, and i dont think i've ever even seen a write up for one. good luck
nizmo559
Post by nizmo559 » 14 Dec 2005 22:01
My buddy has a 620 pick up with a 350. Its a hack job and the gas milage is horrible. Fun truck though.
vgwagon
Post by vgwagon » 15 Dec 2005 07:25
Try the rover aluminum 215 cu v8, lighter than the 4 cyl, distributor up front, and because it's light you wouldn't have to cut the firewall to get the weight back.
Denis Gagné
AKA VGwagon
69 510 VG30e swapped
73 240z VG30et swapped
Derek
Post by Derek » 15 Dec 2005 08:32
A guy named Matt Guzzetta has a long time 5.0 powered 510. He used to have a webpage about it but I can't seem to find it now. Here's a brief blurb from the DQ here:
http://www.dimequarterly.tierranet.com/ ... 69915.html
As I recall, the car had major firewall reconstruction and he used a Corvette rear end.
hoho -- found more: http://www.grmotorsports.com/board/view ... 25a5c2b368
BanzaiDime
Post by BanzaiDime » 15 Dec 2005 09:15
why not scrap the project.. I'll trade you my V8 Camaro for the 510
510six
Post by 510six » 15 Dec 2005 10:16
http://forums.hybridz.org/showthread.php?t=103512
I wouldn`t be concerned about putting a Corvette rear suspension in a 510.My setup uses the R200 with a NISMO LSD and has survived numerous drag launches on slicks with over 500rwh and 490fpt.IMO a V8 in a 510 would be kinda cool, but it would be so much easier in a 240/260/280z car.The car I started with was less than perfect as I would not have started carving on a perfect or even a pretty nice 510.
Post by icehouse » 15 Dec 2005 12:32
The problem I see besides gas price's is getting traction without ton's of body mod's. If it's a nice car you should leave it and at least find a shitty sheel to chop up. It's not my car though. What ever you end up doing good luck.
