can you put a newer (like '72) style dash in a 69?
Yellowcar
Post by Yellowcar » 14 Jul 2006 09:31
thanks
banzai510(hainz)
Post by banzai510(hainz) » 14 Jul 2006 10:34
My yellow car is a 69 witht he later dash
Eric Edwards(privious owner) and Dave Carrol did the conversion.
cant say more than that but pretty staright fwd but gas gauge/temp gauge seem slightly off
make sure to get blinker emerg switch also
Post by Byron510 » 14 Jul 2006 15:10
Converting a 69 to a 70 on dash isn't too hard. There will be two mounts that you will need to add on the lower corner of the 69, if you are installing a later dash. Make sure you get the heater controls with the newer dash - cables are different. If you are working on a 68, then there's more work involved, as the heater unit is totally different and I'm not sure about the windshield vents. In either case, the wiring is different, and if you are taking the dash from a donor car, I’d suggest grabbing the entire dash, under hood harnesses and fuse box.
I converted my car (69) to a Canadian 68 dash, which was a bolt in, so that I could use the 69 SSS Coupe gauge cluster. I did not install a heater, which is a real problem if it rains - not recommended, and I'm looking for solutions.
jonmorine
Re: can you put a newer (like '72) style dash in a 69?
Post by jonmorine » 29 Sep 2009 12:39
Sorry. Digging up an old thread. Can you put just a glovebox from a 70-73 into a 69? Or would I have to complete the whole conversion? My glovebox looks like poo.
2009 Subaru STI
1969 Datsun 510
2009 VW Rabbit
Post by okayfine » 29 Sep 2009 12:52
jonmorine wrote:Sorry. Digging up an old thread. Can you put just a glovebox from a 70-73 into a 69? Or would I have to complete the whole conversion? My glovebox looks like poo.
No. They're completely different, and it probably wouldn't look any better once you did.
What part is bad? I have a good-condition glove box well for a '69, and I have (somewhere) other assorted parts.
jonmorine
Post by jonmorine » 29 Sep 2009 12:57
The well actually has a whole cut on the top section for some reason. Its nothing I can't live with. I have a newer glove box and I just wanted to be sure before I started to tear things apart.
2009 Subaru STI
1969 Datsun 510
2009 VW Rabbit
Post by Byron510 » 29 Sep 2009 12:58
No the later glove box will not fit, the dash is a totally different shape with the later dash (70-73) being physically taller, and deeper. A complete conversion would be required, as well as the necessary electrical changes.
What part of your glove box is weathered? The door or the cardboard insert behind?
I know that most 69 dashes didn't last the years very well. The plastic warps in the sun light, and the padding tends to crack and disintegrate. The 68 dashes faired much better because they were all metal (in Canada) - US 68 dash is a different story. All years of dash pads, however, are subject to the blazing rays of the sun, and if not properly protected (like keeping them out of the sun all together), then they will also warp, crack and otherwise look like crap!
jonmorine
Post by jonmorine » 29 Sep 2009 13:09
The outside part of the box is completely faded and the interior has been cut for some strange reason.
2009 Subaru STI
1969 Datsun 510
2009 VW Rabbit
Post by okayfine » 29 Sep 2009 13:12
Byron, can you point me to pictures of an all-metal '68 dash?
Jon, PM me your e-mail and I'll send you a couple pictures of the '69 well I have. Actually, if you could post a picture of what you've got, I'll dig up bits of what I've got (uh, if I have anything other than the well). Shipping would be fun, though. :(
Post by Byron510 » 29 Sep 2009 16:49
okayfine wrote:Byron, can you point me to pictures of an all-metal '68 dash?
Sure, Julian - rusty and all!
I try to find a photo of Ole Blue's dash, but these two of Rich's wagon will give you an idea. The only thing not metal is the pad - even the ashtray in 68 was all metal, unlike the 69 one which was plastic. This pad has a slight warp to it, new they were entirely flat (and someone added Kmp/h conversion to the speedo in yellow which also should not be there). This is the same dash that is now in the Bronze, with the 69 SSS gauge panel.
jonmorine
Post by jonmorine » 29 Sep 2009 17:44
I am away on business until Friday but I will take a pic then. I will send you my email. Thanks Julien
2009 Subaru STI
1969 Datsun 510
2009 VW Rabbit
