the BEST DIY rear cross member?
Post by defdes » 06 Dec 2006 21:22
I just found what Byron refered to earlier "Com10 Bearings" http://www.aetnascrew.com/com%20bearings.htm
Baz
post subject
Post by Baz » 08 Dec 2006 02:06
V4 is finished & for those that want to make their own, here are pics of the modified adjuster bolts. they are 4140.
Yellowcar
RE: post subject
Post by Yellowcar » 08 Dec 2006 08:46
what is better about the new version?
Post by defdes » 08 Dec 2006 09:06
Thanks for posting the trade secrets Baz, I never would have dreamed of asking. :wink:
Baz
Re: RE: post subject
Post by Baz » 08 Dec 2006 15:37
Yellowcar wrote:what is better about the new version?
They are now R200 ready so no mods needed to fit, still ok for 160/180.
Minor tolerance correction.
The 4140 adjuster bolts.
3.5" or 4" exhaust opening.
this will be poss the second to last upgrade on the std X member if at all. Which will remain in production.
next year we move on to our full fabed X member to take short nose 180/200 diffs. these are easy to obtain in VLSD or mechanical and cheap to obtain.
modded arms to take inner & outer CV shafts with R32/33 rear bearing carriers. will take the S13/14/15/R32/33 rear brake assy depending on version will also be available. easy 5 stud conversion this way.
Baz
Post by Baz » 08 Dec 2006 15:47
defdes wrote:Thanks for posting the trade secrets Baz, I never would have dreamed of asking. :wink:
No probs, is not that what the 510 community is about.
I have learnt a few things from this forum & borowed a few ideas :roll:
Not withstanding the above, I do admit to keeping a few things close to the chest.
duke
Post by duke » 08 Dec 2006 15:52
Baz, do you guys machine those in-house?
Post by defdes » 11 Dec 2006 18:13
I was talking to Gwan about this spherical bearing steel spacer conversion, he said he had made solid aluminum bushings in his ITC car and that it was NOISY, to the extent that he had to take them out. Will the experience be similar with the spherical bushing and steel spacers?
Post by Byron510 » 12 Dec 2006 07:08
I'll asume his solid spacers were noisy because they my have rattled in the bore. I had aluminum bushings on my sway bar and had the same issue - they are gone now. This is not an issue with the com10 set up. I don't hear anything out of mine, in any situation. It's bolted up tight.
thisismatt
Post by thisismatt » 12 Dec 2006 08:33
I was thinking the same thing, Byron
I'm your huckleberry.
Post by defdes » 12 Dec 2006 08:45
Cool. I'll give it a go then. Gonna start tearing the rear end down today.
thisismatt
Post by thisismatt » 12 Dec 2006 15:06
defdes: you should expect a noise increase still, but it shouldn't be too horrible ;)
Post by Byron510 » 12 Dec 2006 19:46
After you're running stiff springs, stiff shocks, and low profile tires with real grip coupled with an ITB manifold, big free-flowing exhaust and a spartan (if any) interior - a little road noise is suddenly inconsequential. I have all the above (including no interior) but my car is not a boulevard cruiser.
Chicks only dig my car... from afar!! (I should put this on a shirt with a photo)
Don't even bother offering a ride, be selfish and keep that for your self!
Post by defdes » 12 Dec 2006 21:17
Byron510 wrote:Don't even bother offering a ride, be selfish and keep that for your self!
I couldn't, even if I wanted to...
duke
Post by duke » 12 Dec 2006 22:39
I got into a discussion on the bb list about loud cars, rough suspension, stripped interiors, etc. and I have to say that alot of the guys on there are total wusses. I guess you northern folk are all just more manly than alot of the guys down here.
