Window Squeeges
DryHeat
Window Squeeges
Post by DryHeat » 17 Oct 2007 21:19
I am finally replacing all of the rubber on my wagon (minus the rear window rubber) and I need some advise. I ordered a complete kit from DatsunLandSoCal and so far everything is working great.
The old outer window squeeges are stapled in place between the chrome trim and a strip of metal. How can I attach the new ones? Any ideas will be appreciated.
hang_510
RE: Window Squeeges
Post by hang_510 » 17 Oct 2007 23:05
1) you can $$$pend for new chrome strips
2) replacement rubber strips from DLsocal are avail (they were before) and restaple on.
3) cheap :!: =buy the longest wiper blades (~24") trim the backing and to length and use black RTV to attach. if done clean & careful, it comes out nice.
S15DET
RE: Window Squeeges
Post by S15DET » 18 Oct 2007 05:59
I just did this, so here goes.
-Use a dremel or some other tool to cut the backs of the staples.
-The inner metal strip will not be re-used. I had to severely bend/roll it to pull out the rusty staples, even after being cut.
-get the new rubber strip as straight as possible, this is important.
-check the length and trim if necessary.
-attach the new rubber to the chrome strip with the included metal clips. 6 per side
-Press onto top of door using original metal clips inside chrome strip.
Mine was a perfect fit, hope yours is too.
DryHeat
Post by DryHeat » 18 Oct 2007 07:13
Metal Clips? :shock: I guess I need to call Mike at Datsunlansocal and let him know I didn't get the clips ... using clips sure sounds alot easier that staples. I was able to get the staples removed without bengin them too much.
Thanks for all the info gentlemen.
mesojdm
Post by mesojdm » 18 Oct 2007 08:13
ah im in the same postition... i didnt see any metal clips either?? im havin a hellavu time gettin the old staples out. I was thinking of either taking it to a upholstry shop to re-staple them on(has to go through the metal) or just not using staples and RTV gluing it on.. any other suggestions:D
caesarDX
Post by caesarDX » 18 Oct 2007 09:37
Hey guys... I heard that someone purchased ones for the 300zx
brand new and they have everything attached. Only problem
was that the length was longer. With a little work cutting and
forming the square end it looked pretty good.
Anyone else hear of this?
1984 Renault R5 Turbo2 - L' Enfant Terrible
1989 BMW E30 M3 "God's Chariot"
2001 Renault Clio V6 Sport Phase 1
1999 Nissan Skyline R34 GTR V-Spec 1
1968 Shelby Cobra GT 350 Convertible - Sold to good home
hang_510
Post by hang_510 » 18 Oct 2007 10:07
^actually yes.
i grabbed some used from the JY and the metal was a PITA to trim down.
i tested it out on the wagon and it came out OK. no vibration and keeps the water out.
being used it was not as tight of a fit as id want, but new may work better. i actually have it on the 2dr now because the PO welded the mirror mount to the frame and the trim job from the wagon is ~1/2" short. close enough for now!
duke
Post by duke » 18 Oct 2007 11:08
what year 300zx?
hang_510
Post by hang_510 » 18 Oct 2007 11:31
^ :?: not sure. dunno if there is any diff between years as they all looked similiar and i took the best set i found.
it happpened to be a RARE day w/ a 510 still there and i just grabbed one off and tried it.
ill (eventually) get a shot of mine installed.
joker72z
Re: Window Squeeges
Post by joker72z » 31 Jan 2009 12:30
It's time for me to replace my squeegees as well and my thought was to see if a 240Z squeegee would fit. I've owned both but never took a close lok at them to see how close they are. Replacements are readily available with chrome and rubber attached so it would be interesting to know if anyone has tried this on their cars. I've heard a pair is only around $100 so it's a great alternative $$ wise.
Any feedback would be appreciated.
Chris
Never start vast projects with half-vast ideas
1971 510 2dr, 58KM original
1/74- 260Z, 66K orig miles - SOLD
1/73- 510 2 door bare shell - SOLD
djlotus
Re: RE: Window Squeeges
Post by djlotus » 31 Jan 2009 23:21
hang_510 wrote:3) cheap :!: =buy the longest wiper blades (~24") trim the backing and to length and use black RTV to attach. if done clean & careful, it comes out nice.
I'm diggin this idea, then again I have no monies, so yeah
duke
Re: Window Squeeges
Post by duke » 01 Feb 2009 00:01
I recently pulled some from a 300zx (mid-late eighties) and cut them down to fit. Work pretty good, not super tight, but better than nothing. Plus, you can't beat $3 at the JY.
joker72z
Re: Window Squeeges
Post by joker72z » 01 Feb 2009 05:37
I like the 300z idea but for some reason, the 240Z stuff looks really close in shape and size. I'm going to see if Specialty Engineering has any spare parts kicking around to compare them and I'll get back to this thread afterwards. I'm ultimately looking for something clean and tight fitting that still retains a stock look.
johnnygalt
Re: Window Squeeges
Post by johnnygalt » 14 Feb 2009 14:36
Any update? My car is missing the squeegees so I'm really interested in this thread. Wish there was a way to subscribe like in VBulletin based forums.
joker72z
Re: Window Squeeges
Post by joker72z » 14 Feb 2009 14:54
Unfortunately I haven't gotten around to trying the 240Z squeeges to see how close they are. Hopefully sometime next week I can get down to Specialty and see if they have a spare set I can borrow to test fit and compare. I'll let you know what I come up with.
Chris
