Page 3 of 3
Re: Window Squeeges
Posted: 06 Mar 2009 09:44
by hang_510
joker72z wrote:I think I am going to order a pair to test fit on the new 4 door.
8) for being the guinea pig!
check out how they fit the rear doors too!
Re: Window Squeeges
Posted: 06 Mar 2009 09:55
by joker72z
I actually ran downstairs to see how each door looks for wear and I only need the driver door. I'm still going to replace both fronts and if they fit really well, I will post up some pics and think about replacing the rears as well. I also need inner door rubber as well but that is pretty reasonable to buy as an aftermarket item ( I think) ).
It should take about 7-10 days to get the pieces from Black Dragon as they are really slow but I will update this thread once I get them. If anyone does theirs first, let us know.
Chris
Re: Window Squeeges
Posted: 06 Mar 2009 10:00
by hang_510
joker72z wrote: I also need inner door rubber as well but that is pretty reasonable to buy as an aftermarket item
yes. seems to be a common part, so not too outrageou$
should still be avail from nissan (IIRC its in the part# sticky)
Re: Window Squeeges
Posted: 06 Mar 2009 10:58
by johnnygalt
Just for the heck of it, I called Long Motor Corp, the parent company of Black Dragon, Victoria British, etc to see if they know what a huge opportunity the 510 community is, especially compared to some of the low production # British car marque's they support. We'll see if the marketing guy calls me back.
Re: Window Squeeges
Posted: 07 Jan 2021 21:17
by ostaylor
It has been a long time since this thread was commented on... Has anyone found a source for 510 Window trim / squeegee replacement? My trim is perfect but the rubber on both doors is pretty bad. Would love to find a viable replacement.
Re: Window Squeeges
Posted: 07 Jan 2021 21:59
by MikeY
All your rubber needs can be met by datsport in Australia. Well worth the money and effort. The best quality there is.
https://datsport.com/rubber-menu.html
Re: Window Squeeges
Posted: 08 Jan 2021 11:48
by ostaylor
MikeY wrote:
07 Jan 2021 21:59
Thanks! I had been to their site, but missed the specific line item. I'll contact them - I'm interested in whether the outer window belt seals come with the steel part. On my current trim, the chrome trim is in great shape but the metal that holds the rubber seal is quite rusty so I'd like to replace both the rubber and the steel that holds the rubber to the trim.
Re: Window Squeeges
Posted: 08 Jan 2021 12:39
by MikeY
:idea: The rubber they sell does not include the steel stiffener. But there rubber is stiff enough to use without the strip. Not that i was happy about gluing the rubber to the stainless trim, that is what they advise. So it's not stapled. They recommend loctight 401 I think. Or some other number. It seemed like crazy glue. Ive done it that way on the last restoration. But it's only been 6 months of non use. Ive heard of someone reusing the staples and drilling little holes. Pretty tedious. Baz and Tracey at datsport seem really nice and go back a long way. So I've come to trust them.
Just for context. Ive owned a 510 since 76. Not the same one. Lol. And been restoring them for about 5 years. I'm in semi retirement and do one a year. Full rotisserie jobs. Very satisfying. Currently booked 4 cars ahead. Takes me to 67 years old and hopefully full retirement.Lol.
I've still got a few cars of my own I'd like to get to.
Re: Window Squeeges
Posted: 08 Jan 2021 15:01
by bertvorgon
viewtopic.php?f=3&t=25088&hilit=bert+vo ... t&start=45
Don't know if this is any help, but, here is my thread of what I did. As Mike said, it is a bit tedious but, it turned out perfect when done.
I DID NOT reuse the Datsun staples as you will see, they are beyond tough and you would never them them straightened out properly anyhow.
One of those projects that you make a pot of coffee and just sit down and get'er done!
Re: Window Squeeges
Posted: 09 Jan 2021 00:03
by cartel
ive actually got both Datsport and NewDatsunParts inner and outer squeegees here now- my pumpkin car came with Datsport ones installed - i then bought the local ones to compare
INNER--the NDP (lol) ones are a nicer profile- a lot shorter and rounder looking and look more like original than the Datsport ones are IMO-
Outer_. . Datsport is more like the original being a flat L shape my pumpkin car has these and one is coming off (P/0 did the install and whatever glue was used didnt hold ) The NDP outers have a lip on them that can sit on the chrome edge- and it has a felt looking lining - i will be installing one just to compare how it looks installed - but its significanly thicker than the Datsport one so im not sure it will work as well - but before i make final judgment i want to see it mounted on the steel completely
Datsport suggested i use a layer of windshield urethane as a base and then black w/s adhesive . (or was it contact cement to that) cant remember now
NDP told me to just use 3m weatherstrip adhesive but in the past on mustangs its never been 100% successful so i dont have high expectations of that lasting-
and the slightly rounded staples i actually have from mustangs as they give you both in a box and most are held in with clips only and the staples arent needed
Re: Window Squeeges
Posted: 09 Jan 2021 23:09
by ostaylor
cartel wrote:
09 Jan 2021 00:03
Interesting... I'd like to hear your final opinion Mike. Obviously easier to get them out of the US if they are of similar quality. I'll need to look at everything I want to order and see if one of Datsport or NDP has everything. I like that NDP has a lot of OEM parts.
bertvorgon wrote:
08 Jan 2021 15:01
Thanks for the pointer to that article Keith. If the steel that the current squeegees were attached to was in better shape, I'd probably give that a try but mine are pretty badly rusted so not really an option. I suppose I could try to fabricate new ones but my metalwork skills and tools are pretty limited.
MikeY wrote:
08 Jan 2021 12:39
Thanks for responding Mike. Sounds like an interesting semi-retirement to be working 510 projects like that. Would love to see some pictures of the finished projects sometime.
