high performance L18?
badgti
Post by badgti » 13 Nov 2007 06:32
guys,
how do i go about building a performance L18 engine that i can use for trackdays?i plan on using 40dcoes on the L18, but have not much idea on wht other mods i need..
Dimebag
RE: high performance L18?
Post by Dimebag » 13 Nov 2007 08:10
I know a guy who is selling a Specialty Engineering turbo L18. He had it built years ago and I don't think he ever got around to actually assembling it. 510ROB might know the specs on it. The components are in Vancouver BC.
John Thiessen
72 Wagon
heirfaus
Post by heirfaus » 13 Nov 2007 08:17
Turbo L18, sounds fun :twisted:
My opinion is that unless you have a turbo L series, you should swap if you want a track day car. IMHO that is..........
Corky Bell, Maximum Boost
-defdes
Re: high performance L18?
Post by okayfine » 13 Nov 2007 08:41
badgti wrote:guys,
What is your budget? What are your expectations? What are your abilities?
badgti
RE: Re: high performance L18?
Post by badgti » 13 Nov 2007 16:26
i prefer a worked n/a l18 ,with high revving capabilities rather than a turbo as i have a evo 2'd colt and since i bought the 510 ,was really keen on building a complete replica of the BRE510 for daily use and weekend curcuit.
Derek
Post by Derek » 13 Nov 2007 18:41
heirfaus wrote:Turbo L18, sounds fun :twisted:
Funny, my NA L18 kept up with E30 M3s and (slowly driven) S2000s at Horse Thief Mile...
Post by 510rob » 13 Nov 2007 19:32
Dimebag wrote:I know a guy who is selling a Specialty Engineering turbo L18. He had it built years ago and I don't think he ever got around to actually assembling it. 510ROB might know the specs on it. The components are in Vancouver BC.
A turbo L18 with the old Engine Air turbo kit (based on the 3ld-168.68 spec turbo) should make ~185HP at the wheels.
badgti
Post by badgti » 14 Nov 2007 08:04
if for high revving n/a setup wht would be neede to be done in the engine other than balancing bottom end, are there any ways i can get the l18 to perform wit the twin 40dcoe's i hve?
Post by 510rob » 14 Nov 2007 08:50
In the grand scheme of things, twin 40s arenn't very big at all and make a perfectly streetable (although thirsty) setup.
You should define what you imply by "high revving" because that means 6000rpm to some people, 7000rpm to others, and 8000+ to others
Dimebag
Post by Dimebag » 14 Nov 2007 09:47
Christmas is coming... THIS BOOK is at the very top of my wish list, and it sound like a good read-through would benefit others around here too.
John Thiessen
72 Wagon
Post by 510rob » 14 Nov 2007 09:59
There was a copy of that 1st edition on E-Bay a few weeks ago that sold for about $15...
There are two versions of that book.
1st edition = How To Modify Datsun Engines and Chassis
2nd edition = How To Modify and Race your Datsun
The 1st edition had the excellently written camshaft article penned by Racer Brown, 42 pages in total. The 2nd edition has the same camshaft article, only it's the massively abridged version which is too bad...
bigjim5551212
Post by bigjim5551212 » 14 Nov 2007 20:09
I have an original. I had a mint condition one some years ago that I sold on Ebay for 65 bux
"He forgot more than what i know about a Datsun"
hang_510
Post by hang_510 » 14 Nov 2007 21:03
i bought the red wagon i had from 'bob waar' (say it w/ a red neck drawl), could find my copy before he moved :evil:
got an L18 with it (is that on topic :?: )
Rehs
Re: RE: Re: high performance L18?
Post by Rehs » 17 Nov 2007 13:07
badgti wrote:if for high revving n/a setup wht would be neede to be done in the engine other than balancing bottom end, are there any ways i can get the l18 to perform wit the twin 40dcoe's i hve?
Longer Rods and Short Flat Top Pistons with valve reliefs... Bore it out at least 0.040"-0.080" over for less shrouding of the 44/38mm valves you're going to have installed in the head while you get it crazy ported. Racer Brown #391-R Cam, with components to match, max effort and lightweight everything valvetrain w/spray bar... Properly balanced and blueprinted bottom end, with a comp header and good free-flowing exhaust... what do you think? You think those DCOE40s he has, with some big chokes, would be good enough for 9,000RPMs? Probably need more carburetion.
badgti
Post by badgti » 17 Nov 2007 15:26
40dcoe's are not enuf for 9k rpms? currently i am trying to source for the l28e n.a pistons that are supposed to be flat-tops rite?but they're hard to come by .wht kind of compression will i roughly get if i use a thinner headgasket(i can get metal headgaskets) 0.7mm and just shave the head 0.4mm off?
