front hood strut part numbers
toylet
Post by toylet » 08 Dec 2007 15:45
i have checked this site and am unable to find to the
part number for gas charged hood strut conversion...
does anyone know?
freaky510
RE: front hood strut part numbers
Post by freaky510 » 09 Dec 2007 11:44
I think i got all the numbers off the dime quarterly.
toylet
Post by toylet » 09 Dec 2007 20:57
i was unable to find those numbers
pimp1911
Post by pimp1911 » 10 Dec 2007 04:36
1971 Datsun 510 2 door
1972 Datsun 240Z
2003 Nissan 350Z
heirfaus
Post by heirfaus » 11 Dec 2007 14:28
Parts I used, Napa part numbers:
(2) 819-5568 Struts $20.45ea
(4) 735-3607 Ball stud $3.99ea
Napa Auto Parts. These are the ones I used and it works PERFECT!!!!!!!!
Corky Bell, Maximum Boost
-defdes
mesojdm
Post by mesojdm » 11 Dec 2007 14:39
the mount for the hood can go on the hinge..the other end of the shock that mounts on the inner fender well....theres a small section that is 2layers thick of metal....be sure you go there as anyother place is 1 layer and could tweak easily
sexyL
Post by sexyL » 11 Dec 2007 15:02
mesojdm wrote:the mount for the hood can go on the hinge..the other end of the shock that mounts on the inner fender well....theres a small section that is 2layers thick of metal....be sure you go there as anyother place is 1 layer and could tweak easily
which ones did you use again? i pmed you about it and i think you said something like a civic hood strut. or am i wrong? do you know the part number?
traitorjacknif
Post by traitorjacknif » 11 Dec 2007 15:08
I think its a 92-95 Civic hatch strut.
toylet
Post by toylet » 11 Dec 2007 20:53
thanks you guys are great
sexyL
Post by sexyL » 12 Dec 2007 06:31
is there a way you can check the parts numbers on Napa's site? or do you need to call in.
heirfaus
Post by heirfaus » 12 Dec 2007 08:18
If you have a specific application you can do it on the web, but I don't think you can with a part number. I have no idea what the ones I used are from.
Wurker and I just went to the warehouse and checked their catalog. We grabbed the ones with the longest.....um....spacing out....um.....shaft movement.....um....really sounding dumb now......STROKE that's it!!
So anyway I have no idea what the application is so for the napa part numbers above you can call them.
-defdes
toylet
Re: front hood strut part numbers
Post by toylet » 03 Mar 2014 05:50
sweet I will order them tonight
McShagger510
Post by McShagger510 » 03 Mar 2014 21:20
:lol:
'91 Nissan truck
