wheel fitment 510
Crevier
wheel fitment 510
Post by Crevier » 02 Feb 2008 20:26
wondering if 15x7 0 offset under unflared rear fender will fit? with 205 50?
510-Trevor
Re: wheel fitment 510
Post by 510-Trevor » 02 Feb 2008 21:09
I used the search and found this: (check page 2) http://www.the510realm.com/phpBB3/viewt ... set#p71836
1972 Yellow 4dr
sil8y
Post by sil8y » 06 Feb 2008 15:46
yes it will. ...by just a hair. but i recommend that you go with a 195 50 over the 205. i have 205s on my 15x8 0offset and i wish i would have gone 195s. you could even go for a 185 65 or a 175 65 and it would look great. i had to roll the s**t out of mine with the 8s and the 205s.... but mine is slamed! :)
duke
Post by duke » 06 Feb 2008 19:55
They do fit, but require the use of 280zx struts because they narrow the front track a little. A little bit of front camber also helps. The fenders will also need to be rolled. In the rear you will need to roll the fenders and run a good amount of camber. So yes, they can be made to fit under stock fenders, but IMO, for proper alignment and best performance, flares are needed. Search the site, cause I have written this a few times.
sil8y, do you have any pictures of you car? I'd like to see how the wheels fit.
Tyler
Post by Tyler » 10 Feb 2008 20:00
here a site that will give u almsot everything u need to know
http://images.google.ca/imgres?imgurl=h ... n%26sa%3DN
