Wagon wide body?
Wagon wide body?
Hey, new to the site. Thanks for looking.
I see all kinds of fender flares and widebody kits for the 2 door. but nothin for the sedan and wagon. im lookin for fender flares for my 70 wagon. needs it bad. i have 205 50 15s on 15x8 0 offset wheel. ...it drives... straight. lol
im not worried for the front. but that damn back door has some clearence issues with any kind of bubble flare. any help would be hot.
Re: Wagon wide body?
i have tubbed/ flared a 4 door... not an easy task... unless you like fabbing things and have lots of time and patience don't bother...
switch to 195's and 6 inch tires...
Merlin from Datsunhistory.com
im running into the same problem with my 4 door sedan. do you have any pics of your tubbed/flared wagon?
well, the 15x8 0 offset fit. just need a sway bar and to clean up the flares a bit. i would love some bolt on flares but im not sure what to do about the back.
- johnbureezu
have you tried rolling the fenders a bit? But yeah, I've been contemplating flares on my goon, but it's way involved if you wanna keep rear doors functioning properly. Way later down the road for me. You may have to run 195s.
yeah. they are rolled a ton. ill put a couple more pics up tomorrow. thats all i had on my phone for pics. i wish i had 195s. i will be rotating the 205s out soon enough. i would like to get some bolt on flares for a slightly cleaner look. i may just cut some coupe rears in half and bolt them to the back door...
- zootowndime
http://www.the510realm.com/phpBB3/viewt ... a&start=45
you can take a look through my project thread for some possible ideas, not a wagon but a 4 door with flares, just about the same concept. The rear has yet to be tubbed. School and work are taking up all my time this winter. Gotta save for scca this summer!! Plan to go at getting the rear end tubbed so it will work. Right now i just have the whole original lip cut off, but if i push out the tires to the edge of the flares it still rubs in hard corners:(
Alex King
www.brewedmotors.com
I'm about to reflare my 4 door... the process will be the same on a wagoon... i pick up the flares from specialty engineering next thursday . as soon as I start, i'll start a thread and post pics.
essentially what i did the first time was cut the inner well of at the center seam... where it sticks up and is cover by that flexible trim that goes all the way around the door on the inside edge. then I pop riveted(this time I weld- half the reason for the fix) a sheet of new metal straight out from that seam. You'll need to cut everything but the very inner edge of the door arch out on the door and weld in a matching panel there as well. then you install the flares and fill in the gaps... But
there's two ways to put the flares on, the first is the way they currently are on my car which is to mount them and cut them straight down the door seam at the lock, and straight across on the rocker line to the wheel well.. this works fine but looks a bit hacked... you're flare is actually three pieces, on small piece on the rocker, about a 3rd on the door and the rest on the rear quarter.
the way I'm going to redo them is to leave the flare arc whole and shrink the door up and forward... the door skin will be nearly flat and the flare will start where the door arc ends, much like a modern flared car.
nice thanks. do you have any pics of just the rear flare?
how do you post a pic now?
nevermind - duh! here's the only pic i can find from the pre digital days.
- RWD_NissanMan
Here's my documented build of 2-1/2" steel flares for the rear of a 4-door. Quite a bit of fabrication but we were able to retain the useage of the rear doors. It would be the same process for a wagon.
http://www.the510realm.com/phpBB3/viewt ... f=3&t=1877
yup, what RWD has done is essentially what i did the first time in the way of cutting metal out.... how he;s finished them is how i'm going to redo them... instead of welding in the stock inner wheel though, i'm going to try and use a sections of a pair of trailer fenders i bought at princess auto for 30 bucks... the curve is a very close match to the 510 wheel arch
