Whitebird
Re: Whitebird
Post by goichi1 » 28 Sep 2014 23:30
[quote="okayfine"]Removed wiring I won't need:
The attachment IMG_5887.jpg is no longer available
Julian's Wiring copy.jpg (240.38 KiB) Viewed 2114 times
Re: Whitebird
Post by icehouse » 29 Sep 2014 07:07
Have wife crank engine over. While she is cranking the engine over smack injecters with the back side of your screwdriver, switch between all four, should fire up.
Re: Whitebird
Post by okayfine » 29 Sep 2014 08:15
Hey Rich, I see what you circled, but I don't remember what that plug is. FWIW, I used a fully KA24DE harness, so there was a lot to pare.
Will give the injectors some what-for today. Going to rummage for some spares. Jeff, any idea about the ECU light when START? If it's supposed to remain on, then I have a wiring issue. But the stumbles I get from the engine suggest it is fuel.
Re: Whitebird
Post by icehouse » 29 Sep 2014 12:14
okayfine wrote:Hey Rich, I see what you circled, but I don't remember what that plug is. FWIW, I used a fully KA24DE harness, so there was a lot to pare.
ECU light doesn't matter.
What codes is it giving you?
Whitebird LIVES!
Post by okayfine » 29 Sep 2014 19:48
Threw a junkyard set of injectors into it, and:
https://www.youtube.com/watch?v=vpJlxo26eKM
Still some tweeking to do (timing, idle speed). But a lot further along than this morning.
I pulled the rail with the original injectors and turned key to START to see what they sprayed like. #2 didn't do anything, as expected, and the other three did something...but then I recognize that I didn't really know what it should look like. Reinstalled the rail, changed out the injectors, and Bob's yer uncle.
Re: Whitebird
Post by 510rob » 29 Sep 2014 19:52
awesome!
finn
Re: Whitebird
Post by finn » 29 Sep 2014 20:21
Good deal man. You can send them off to get cleaned or just chance it. Ebay has plenty for a decent price. Glad its running though. Almost time for another fun run.
'69 2dr KA24DET
Pista_510
Re: Whitebird
Post by Pista_510 » 29 Sep 2014 20:35
That's fantastic; great result....! :)
spriso
Re: Whitebird
Post by spriso » 29 Sep 2014 21:00
congrats-- glad to hear that it all works!
Looking forward to hearing about the first test drive!
Michael
Michael Spreadbury
Spriso Motorsports
www.spriso.com
Re: Whitebird
Post by two_68_510s » 29 Sep 2014 21:35
Good job Julian, now drive! :D
Bike papa
Re: Whitebird
Post by Bike papa » 29 Sep 2014 21:41
Nothing is sweeter than hearing your engine start after solving those "not so obvious" problems
Props!!!
1971 Datsun 510 2 door
08 VW R32
69 BSA 650 Firebird Scrambler
Too Many Bicycles
Re: Whitebird
Post by okayfine » 30 Sep 2014 06:18
Thanks everyone. We'll see what happens when I put it in gear.
Re: Whitebird LIVES!
Post by icehouse » 30 Sep 2014 06:50
okayfine wrote:Threw a junkyard set of injectors into it, and:
Damn you were supposed to smack them with the screwdriver so I would have been right..... haha :) The Nissan side feed injectors get stuck super easy if the sit for to long.
Re: Whitebird
Post by Three B's Racing » 30 Sep 2014 07:40
Nice job Julian. Glad it was as simple as that. First drive oh ya!!! in the words of Angel Flores to Walt contemplating on driving his not so ready 510 to Summit Point one year from NY, "Does it run? does it stop? Let's Go!!
First Drive
Post by okayfine » 30 Sep 2014 12:55
So, here's a funny thing. I backed the car out to put it on the lawn and give it a bath. There was clinking from the back, which I thought a bit odd. Finished washing up and stuck it back on the drive to check timing, etc. More clinking. Pop the trunk, there's only the old trunk package shelf sitting in there loose, so I pull it out, then head out to get some gas.
Along the way, lots more clinking. It didn't seem too ominous, nothing felt bad. Then I figured it out...it's the hinged gates for the baffles!! :lol: They're clicking and clacking closed as gas moves around. How bizarre.
So, initial drive impressions. After working through some sitting issues (brakes grabbed initially, trans grunched in reverse before it pumped up the slave), it drove pretty nicely. Not 100% yet, but I felt no fear in taking it straight from the garage to go get some gas. Normally I'd putter around the neighborhood for a while.
Things to do? Not much. Temp gauge doesn't read, but I ground the wire and the gauge is still functional, so there's something wrong with the new sender, which is kind of a PITA. Idle is a few hundred rpm high, and the cold-start might have some issues. We'll see if those get better through some actual driving.
It felt good to have it back on the road. Added the current reg sticker, so I'm GTG.
