Chris' 72 Project
Derek went with a 300ZX throttle that was a bit smaller than the 240SX unit... I think either one would work equally well and both are quite plentiful. We pulled a couple throttles from 240SX 12-valve motors at the wrecker. If you don't want to pay "sports car" part prices at the wrecker, pull one off a Mercury Villager minivan or Nissan Axxes minivan (then it's "minivan" part prices!)
I forgot to post a pic and I don't think I mentioned it, or maybe I did. I have a L28 throttle body with tps and olschool linkage. Is that the same diameter as the 240sk unit?
I finnally bought the megasquirt kit yesterday. Now I just have to build it, and get the last odds and ends, but who knows how long that will take......
I almost got distracted, and started a rear disk brake conv. but I barely decided to stay focused on the EFI.
About 400 US for rear disk conversion complete and I don't have to fabricate anything!!
Oh well that will have to wait.
Corky Bell, Maximum Boost
-defdes
-defdes
I think someone who has one should go measure and let us know!heirfaus wrote:I forgot to post a pic and I don't think I mentioned it, or maybe I did. I have a L28 throttle body with tps and olschool linkage. Is that the same diameter as the 240sk unit?
richard norrish
Chris,
I have a feeling that the L28 throttle position sensor will NOT work with megasquirt (or any other programmable EFI setup - for some reason I think it's a switch box, not a ratiometric potentiometer)
measure it with an ohmmeter and make sure it's compatible with the EFI stuff before you fabricate a bunch more shit around it...
By the way, which MegaSquirt did you go with?
The 280ZX/200SX is just a switch box, one for idle, one for full throttle, and one for anywhere in the middle. That's all the L jetronic system needed. I know this for sure, as I took one apart 11 years ago when I started my own EFI project.
Thanks for the tip.....and it's funny that I fix cars but don't think to measure my own throttle body before asking!!!!!!!!!!!!!!
-defdes
-defdes
Oh and I bought the basic version 2.2, I figure it will work for now. It's funny I'm on a tight budget until august when I get married. I figure I would save some coin and get the less expensive, now and then go big later this year.
-defdes
-defdes
- datsunfreak
IIRC, the L28E TB is a 48mm unit. Honestly, it's too small for what you are doing. The 300ZX TB is a 55mm (good, but on the conservative side), and the 240SX is a 60mm (good, but on the big side).heirfaus wrote:I forgot to post a pic and I don't think I mentioned it, or maybe I did. I have a L28 throttle body with tps and olschool linkage. Is that the same diameter as the 240sk unit?
Personally, I would go with the 300ZX. I've used a few on 4 cylinders and they seem to work nice, without any noticeable tip-in.
FWIW, you can swap the later 300ZX potentiometer TPS onto the early 280ZX TB. Just takes a bit of slotting of the holes I believe. I did it once, but it's been about 6 years ago...
Ok so the only tought thing about this is finding the time. I only got in 20 min yesterday, and about 20 min today. So I guess it'll take a little longer than I thought, but don't work for the next 2 days, so should be done soon
I love the setup for putting the flyback in, but I doubt myine will be that pretty, oh well we'll see
