Chris' 72 Project
ALRIGHT!!!!! You just can't beat a good deal. It makes my day!!! I just got my injectors in the mail today. All 8 Bosch injectors and shipping was $60. Thats 7.50 USD each. WOW!! Anyway, almost done aquiring the goods!!
Corky Bell, Maximum Boost
-defdes
-defdes
-Intake Manifold
100USD EBAY
-Throttle Body with TPS
20USD EBAY
-Fuel Injectors
26USD EBAY
-Fuel Injector O-Rings
2USD Baxter
-Fuel Rail
20USD Internet
-R drill bit, Q tap
8USD Tool Store
-1/8 NPT nipple for injectors
5USD Baxter
-FPR
42USD Baxter Auto
-MSD Fuel Pump
80USD EBAY
-MS Computer & Flyback
170USD DIYAutotune
-Coolant Temp Sensor
11USD Baxter
-Intake Air Temp Sensor
11USD Baxter
-Pigtails X2
18USD Baxter
-USB to Serial
20USD Best Buy
NEED TO BUY
Throttle Cable 40USD Baxter
O2 Sensor 50USD Baxter
MS Harness 50USD EBAY
NPT Nipples and Taps 20USD
What Am I missing?
Total is about 690
100USD EBAY
20USD EBAY
-Fuel Injectors
26USD EBAY
2USD Baxter
-Fuel Rail
20USD Internet
-R drill bit, Q tap
8USD Tool Store
5USD Baxter
-FPR
42USD Baxter Auto
-MSD Fuel Pump
80USD EBAY
170USD DIYAutotune
11USD Baxter
11USD Baxter
-Pigtails X2
18USD Baxter
-USB to Serial
20USD Best Buy
NEED TO BUY
What Am I missing?
Total is about 690
-defdes
-defdes
Oh yeah, My dad has a drill press and I gave him my fuel rail stock and it should be done by now. I am hopeing to have the manifold mockup done today
-defdes
-defdes
So here is the first mock up.
I was fortunate enought to get all injector hardware from a 280ZX and it mounts up perfectly. Also have the intake air temp sensor using the GM generic sensor for megasquirt mounted in between runners 2 and 3. That is a 300ZX throttle body, and it bolts right up, couldn't ask for more.
-defdes
-defdes
fuel rail was drilled and tapped for 1/8 NPT and they are supposedly push lock hose fittings. We'll see. If not I'll just use a FI clamp. I still need to tap the ends for fuel supply and return.
The bottom picture shows the throttle hookup. IT swings down as it opens. When I use the Lokar cable I will be putting a bracket in the pre-drilled hole on the manifold to hold the cable.
-defdes
-defdes
Wurker, You save ALOT of doh re me with ITB's, right? I mean throttle bodies, tps, injectors, fuel rail, fuel pressure regulator, and map sensor all in one piece right?
-defdes
-defdes
Throttle bodies, tps, injectors, fuel rail and wiring for them were about $55 shipped (ebay). No need for the map sensor - it's on the MS board I'm running my fuel pressure regulator in the trunk and running only one fuel line forward. Time will tell if my injectors are big enough.
'70 510 2 door
chopped '69 521
chopped '69 521
