My Coupe Project, back to the future.....
Re: My Coupe Project, back to the future.....
Post by goichi1 » 22 Sep 2015 00:23
well, what a night......can't type so just look at the pics.......
Post by goichi1 » 22 Sep 2015 00:26
hope it stays put till tomorrow so i can get the sheathing on.....it's solid, all the weight is off the lift now and resting on the top plate.
tr6racer21
Post by tr6racer21 » 22 Sep 2015 05:01
This is awesome Rich...congratulations
Post by Three B's Racing » 22 Sep 2015 05:14
They should hire you to raise the Titanic 8>) Nice job!!
Post by Byron510 » 22 Sep 2015 05:53
The photo looks even better because you have power to the lights as it goes up - great pictures Rich - good job and glad to see it all worked out for you. So if the first photo day break or dusk when you started the job? :D
Post by two_68_510s » 22 Sep 2015 06:28
So, are you going to use the sheathing to span that joint between the top and bottom wall? It would seem like it could move at that joint.
Man what a cool thing you have done Rich, very cool! That room must feel as little different eh? How about some inside shots?
Post by James » 22 Sep 2015 13:29
That knee joint is what I worry about as well.
Post by goichi1 » 22 Sep 2015 21:15
yes, I'll sheath it. THe only knee joint in on the front wall, it had the top plate resting on the full span header for the garage door and man door. THe header is the entire length of the front wall. so I built off that for the front wall, basically just framing it like a normal wall. I used blocking between each stud on the top and bottom for that wall. I didn't get to it today but hopefully it will be fine till tomorrow.
The rest of the walls I used full length studs sistered to the existing cut studs. so they go from the top plate to the sill plate. This eliminates any knee wall action. It's a lot of work but I think it will be worth it. I got plywood today to sheath it, not going to use OSB. then I'll have to decide what type siding I'll use....probably going to cover the entire building with Hardy lap siding. Then next year side the house too.
I'll also go back and frame the cripple and king studs for all the windows.
greenthumb
Post by greenthumb » 22 Sep 2015 21:22
Very well thought out imho Rich. One way to look at this is the hoist has probably paid for itself already vs. a conventional rip the shingles and roof off and build up from there. I would have zero qualms about the way this is done.Congrats on some successful (very) outside the box thinking!
Post by two_68_510s » 22 Sep 2015 21:50
That is a great solution Rich! That is one stout building. I think Henk is right, that hoist is almost a freebie.
Post by goichi1 » 22 Sep 2015 22:33
Thank you all....I am not going to lie....it was scary as hell watching that thing go up to 4 feet. I know it don't sound like that much but it's a little less that half the original wall height! Once up me and a friend installed the vertical braces and I felt much better but still tried to hurry to get most of the studs in. Started going up on the lift at about 7 pm and got it to this point by midnight. I think that's pretty good and feeling pretty relieved that it's up without incident.
Post by James » 23 Sep 2015 08:11
Glad you ran the full length studs, I like your projects - always going for it!
I envy your shop space!
Post by defdes » 23 Sep 2015 17:44
Super cool, the ceiling that I want to raise in my shop is easy compared to this.
Midnight? Your neighbors must hate you!
Post by goichi1 » 23 Sep 2015 20:46
well, I live on about 2 acres, and only have two close neighbors, one is 90 and can't hear anyway and the other is too far to bother them I think.
Tonight I tried to hang a piece of plywood by myself, that's not happening, I got it up there but its too high and the sheet it too big to handle on my own......got a friend coming over tomorrow to help me get the sheathing on. it's supposed to rain tomorrow but hopefully if won't be windy.
Post by Byron510 » 23 Sep 2015 23:20
A trick I just leaned for sheeting, hammer a couple of nails in near where the bottom of the sheet needs to be. You can place it, reposition yourself, pull the sheet into place and hit it with the nail gun... presuming you are using one. If not, then yes it's best to get a hand.
Awesome job Rich. Ditto on the full length studs to support the weight between the upper and lower plates. So did you get a few creaks and tweaks of the roof structure as it started to move? Just curious as I moved my 16X25 shed rearwards in my yard, it was definitely protesting as I drug it along! In this case I wasn’t concerned, it's only there to keep the nails and hammers dry until I get the real shed build, then the little shed is 'Outta here!!'.
