1st project post :)
Re: 1st project post :)
Looks nice, but do you have enough slack in those lines for engine movement?
Good point. Maybe that first one is a lil short. The front carb should be fine. I have plenty of extra line so.....
After sleeping on it, I don't know what I was thinking running the hoses like that anyway. They do have plenty of side to side room, but I think I will just run longer one's for each side and then zip tie them to the holes for mechanical linkage on the mikuni manifold for a much cleaner look as well. They will run parallel to the valve cover and then a soft 90 to each carb
I think this is a little bit better
This fuel system is tedious. Almost finished though. Mounted the fuel pump under the back seat. I need to run a wire from the ignition to the back and hook up a relay. Add the fuel filter and that's about it.
I wish I could get the slimline foam unit that attaches to these. Otherwise it will just be an excuse to upgrade the motor
You can fit an ITG set up in there, they look nice,
Where can I get it from?
But then you won't be able to see the yummy bellmouths.
What is there was a really thin thingy dingy filter that you couldn't really see cause it was before the bellmouth?
See pic.
See pic.
Faster is gooder.
- thisismatt
High flow, small size, filtering ability - pick two.Denver wrote:But then you won't be able to see the yummy bellmouths.
See pic.
I'm your huckleberry.
