Adjustable Rear Spring Perch
Dave Patten
Re: Adjustable Rear Spring Perch
Post by Dave Patten » 19 Sep 2018 12:35
I believe Specialty Engineering still sells high rate rear spring that "bolt-in" to the stock location.
Some have used 3"ID off road coilover springs. They have taken an 18" spring, cut it in half to make (2) 9" springs that have one flat end and one with a pig tail for the control arm bucket.
If you cut an 18" - 550# spring in half, you get (2) 9" 1100# springs.
As for adjusting ride height, I've used varied thicknesses of plywood spacers on the chassis end to get the correct ride height and then replaced them with the same thickness steel rings once ride height was where I wanted it. We used steel because we had stock laying around, aluminum would work just as well.
Its a cheap way out, but it works.
Dave Patten
http://www.FutoFab.com
Dunbarton, NH
ray23
Post by ray23 » 20 Sep 2018 21:21
thanks for that info Dave, Fred can post a pic of your dime with the 9" springs. So I went with 8" at 250lbs for the front and 6" at 800 and 8" at 800lbs they are all 2.5" ID springs I got from Eibach since they are close to me. I'm planning on getting some shock inserts for the front that are adjustable (compression and rebound) also the rear I want to get adjustable ones, but not sure what to get? any suggestions? my fronts are DIY 510 coil overs measuring at 15" from inside the tube, the rear I'm not sure where to source one? i've heard people using camaro's but not sure what year? is there a different option? by the way Dave your panels are f'n awesome keep it up bro!
Ray
72 Datsun 510 2 door
86 Ford F250 extra cab 6.9 turbo Diesel 2WD
Fred_L-P
Post by Fred_L-P » 21 Sep 2018 15:53
Fred_L-P
Post by Fred_L-P » 21 Sep 2018 16:00
ray23 wrote:
20 Sep 2018 21:21
KYB 743019 AGX for the 82-02 Camaro is adjustable and works.
By the looks of it, the T3 coilovers are also built around this shock absorber.
Someone correct me if I'm wrong.
ray23
Post by ray23 » 21 Sep 2018 19:42
that looks good Fred! I hope what I bought will work.
Ray
ray23
Post by ray23 » 21 Sep 2018 19:57
any suggestions for the front? my tube has be cut to the same height as the 280zx 15", Ive heard of people using MR2 inserts not sure what year? i would love tokico's but i know they don't make them anymore, Dave do you still have them in stock?
Ray
