Suspension Setups
pokey
Suspension Setups
Post by pokey » 16 Mar 2004 23:54
I've noticed a good number of suspension setup quesitons popping up, and hell I'm curious too. What are people running out there? If people could reply and say what their running, maybe we could get a database of sorts to help out others?
Info like:
Primary use of car. (autoX, rally, street...)
Struts (510, 280zx, 200sx...)
Pound Rate Front?
Pound Rate Rear?
Coilovers?
Sway bar diameters?
Camber/Caster Plate?
Satisfied with this setup?
General Impressions?
Approximate change in ride height?
Brands/ source junked car would be nice...
-Paul
entix
Post by entix » 18 Mar 2004 03:05
prim use: street/soon to be autox
struts: 280zx
rate: 200# all around
ground control coilovers
tokiko 5 ways
rest is stock
very satisfied. the ride is smoother than stock, with little to no body roll. the shocks are a quality part, but didnt come with a dust boot, so well see what effect that has on longevity.
got it all from http://www.ermish-racing.com. bit pricey though..
5teN
Site Admin
Post by 5teN » 18 Mar 2004 09:47
Vehicle: '72 510 Wagon
Use: Street/Autocross
Strut: Shortened 280zx
Shock: VW Golf - Byron details?
Spring: 2.5" ID 8" length, 225lb/in spring rate
Coilovers: Experimental Engineering
Camber Adjustability: Adjustable Lower Control Arms
Comments: Pretty happy with it, can put in lots of Neg. Camber. Car likes to pull over the road but this could be from many other factors.
Spencer
Blk68510
Post by Blk68510 » 18 Mar 2004 14:27
Vehicle: 1968 510
Strut: 280zx
Shock: Tokicco non adjustable
Spring: (front) 2.5'' ID 8'' length 225lb rate
(rear) Cut roadster comp. springs
Coliovers: Hypercoil
Camber adjustment: Ecentric LCA bushings.
Swaybar: 1'' front
Comments: Slight understeer, wich suddenly changes to oversteer in adverse conditions (verry fun in rain :D ). Slotting the rear crossmember and stiffer rear springs, or softer fronts will correct the problem.
73Wagon
Post by 73Wagon » 18 Mar 2004 21:46
When using a coil over setup on a 280zx strut that has been shortened to use a vw rabbit insert and eight inch springs, do you find that in order to run the car on the street the springs must be set at or very near the top of the threaded tube? In other words is using the rabbit insert and a shrotened strut too short and lower the car too much?
5teN
Site Admin
Post by 5teN » 18 Mar 2004 22:14
Hey 73Wagon,
YES i do! Mine are at the top of the strut tube and pre-loaded quite a lot. If it wasnt a wagon and i could have to rearend lower I'd have the front lower so it wouldn't be such a problem. I'm hopeing to try out some 10" springs so I move the perch down a little and get rid of some of the preload.
Spencer
rnorrish
Post by rnorrish » 19 Mar 2004 00:04
sweet, I run the stiffest springs so far...people from Oregon think I'm still crazy from a few years ago on the way to Shasta. That, and the 44 Mikuni's on an 1800...
Front: 250#(2.5" ID x ??), Koni Gas Adjustables, ZX coilovers (ot shortened, custom camber plates, 3/4" sway bar
Rear: Specialty Engineering Road Race, Gas shocks, not slotted, no sway bar.
T/C bushings changed, rest stock
Oversteer in autocross, and on the street too I guess, but it feels more confident than anything. Power oversteer in the rain/snow. Pretty rough up here in Edmonton, but I love it back in the Valley. Good for the Cannonballs!!
richard norrish
supersportsedan
Post by supersportsedan » 19 Mar 2004 08:17
Primary use of car: Daily driver, highway road trip destroyer in the passing lane, minimal autox
Struts: 610 with Bilstein inserts, camber plates, adjustable lower camber bushings.
Pound Rate Front: 300 take that richard! muhahaha!
Pound Rate Rear: Top Secret! (as in, I'm not really sure.) The leafs have been de-arc'ed with a stiffer leaf added. It compliments the front, anyways.
Satisfied with this setup: I suppose, despite the obscurity... :oops: There's a little bliss in ignorance, as I am a recent owner and not the builder of the car, but she sits nice and low and I found out last night that she is solid at high speed. What else do you need to know? :wink:
gooned
Post by gooned » 19 Mar 2004 09:48
supersportsedan wrote:I found out last night that she is solid at high speed. What else do you need to know? :wink:
it'll pull in 5th for a looonnnggg way eh :!:
Post by bertvorgon » 19 Mar 2004 20:25
Summer driver, occasionally used for competition, Cannonballs, misc. other ridiculous speed events.
280zx struts with modified Bilstien shocks 300+/lbs front springs
fully adjustable front suspension. 1 1/8" front bar. 1/2 degree negative camber....lots of caster. Caster makes it incredibly stable at high speed, and induces MORE negative camber the tighter the turn ( Good thing ) Plus A few other Demon tweaks that no one has noticed! Ta, Da!
Rear shocks top secret, as is spring rate ( same as Supersport!) 1/2 degree negative camber , 1/4" TOE IN. No rear bar.
Car set up with very slight nose down attitude.
Car is pretty neutral on turn in, set up for understeer at the limit.
Has reasonable power for over-steer if required by driver. I am a believer for the real world of Cannonballs, etc., to have a car that is NOT taily by any stretch at stupid cornering speeds. For slaloms it likely is a bit too much of an understeerer, I just try not to go past the traction point.
scotth510
Post by scotth510 » 12 May 2004 10:27
I am currently switching to coilovers in the front of my 510. The front springs I was thinking of using are 225lbs and the rear springs I have been offered are 700lbs. Is this setup advisable. I will be using the car for street driving and autocrossing. Any comments will be appreciated.
DO IT, IN A DATSUN.
1968 4DR Sedan
VIN PL-001796
mattc
Post by mattc » 14 May 2004 10:15
the 700 pound rear rate is for a stock location spring. if you are using coil overs on the rear, than 700 is waaaaaaaay too stiff. I run a 600 pounder in the rear (stock location) and a 350 up front with R compound tires in a race use only car. i would cut that by 100 rear and 75 front for strret tire use.
Gravity: it's not just a good idea, it's the law!!
scotth510
Post by scotth510 » 14 May 2004 16:42
Thanks for the comment Matt. I am not using coilovers in the back yet. I've been told to increase the spring rate in the rear to 900 to match the 225lb coilovers up front. From what I've seen of cars with 700lb rears, they are too soft. Please let me know what you think of this plan.
DO IT, IN A DATSUN.
1968 4DR Sedan
VIN PL-001796
Post by bertvorgon » 14 May 2004 17:58
Just a comment on the rears, 9oo Is a good point to start. 700 is definately too soft. Do NOT be afraid to sneek up on 1000. That sounds really stiff to some, but, look where the whell is relative to the spring. Lots of leverage happening. The benefit also is the stiffer the rear, the less tendancy for toe change, which you REALLY feel on a 510.
drignotum
Post by drignotum » 23 May 2004 11:23
I set my car up for mostly street with some autoX usage. 280zx front struts with tokico iluminas (for sw20 mr2 i think), ground control coilovers kit with 225lb 2.5in springs, camber plate/tophat kit, and some spacers. In the rear i have tokico illuminas (for a camaro i think) with ground control coilovers, 250lb 2.5in springs. penultimate Xmember, poly bushes all around....quickor sway bars front and rear. z31 hubs up front...all being put together in the next few days or so.
