alignment
GtsN-95.0
alignment
Post by GtsN-95.0 » 12 Jul 2009 22:01
I know you cant do A alignment on 510's but im have a problem with the camber being to far out on my car the past owner said her cut some boot or somthing like that im not sure but he said thats when the camber went bad but I have looked all around to see what could be causing the problem but I have no Idea. If anyone has anything let me know
Re: alignment
Post by James » 12 Jul 2009 23:22
Front or rear?
GtsN-95.0
Re: alignment
Post by GtsN-95.0 » 14 Jul 2009 08:12
front pass tire is camberd out to much
dislexicdime
Re: alignment
Post by dislexicdime » 14 Jul 2009 16:49
sounds like a bent strut and or strut tube .
Re: alignment
Post by okayfine » 15 Jul 2009 16:15
Damaged or mis-matched parts. Camber is not adjustable from the factory.
