280zx front suspension and 15x7 +15
so I tested the rims and they JUST clear the strut tubes. I am running small diameter coilover springs so there is nothing more really to hit... think that 195 50 15 tires will clear on the front with the wheels just clearing the tube
1972 Datsun 510 Wagon 5spd - SR20DET, 20G, VS-XX
1972 Datsun 510 Sedan 5spd - L18E, twin SU, Riversides
Re: 280zx front suspension and 15x7 +15
one more thing you can do is run a shorter coilover spring on your struts, this will put the spring over the top of your wheel, but requires you to rebuild your coilovers....probably.
spring is already over the top of the wheels.. but I want to lower the perch or something to lower it
when you see how it fits with the tires will you post a pic? id love to see
