wilwood question
htownsr510
wilwood question
Post by htownsr510 » 08 Nov 2009 20:22
I am going to be buying the wilwood brake package from troy emrish but i was wondering since i am upgrading the brakes is it ok to be runnin the same 40yr old oem brake proportioning valve or do i really need to upgrade to a Wilwood adjustable brake proportioning valve?
thisismatt
Re: wilwood question
Post by thisismatt » 08 Nov 2009 20:33
What's your 40yr old proportioning valve from, cause a 510 doesn't have one.
I'm your huckleberry.
htownsr510
Post by htownsr510 » 08 Nov 2009 21:02
I had did a search on here and i read the 510 didnt have one but then I was told by a buddy of mine this was the p. valve Image.
thisismatt
Post by thisismatt » 08 Nov 2009 21:30
It's just a bias switch - if the front or rear fails/loses pressure the switch is engaged in the direction of failure, turning the dummy light on. Even nissan calls it simply "ASSY SWITCH BRAKE INDICATOR".
tycot1
Post by tycot1 » 08 Nov 2009 21:40
so when it fails the e-brake dash light comes on right?
rnorrish
Post by rnorrish » 09 Nov 2009 00:24
htownsr510 wrote:... but then I was told by a buddy of mine this was the p. valve...
come on... who ya gonna call?
er, trust?
richard norrish
Post by bertvorgon » 09 Nov 2009 06:34
Yes, the e-brake light comes on!
This is commonly mistaken for a brake bias valve.
Post by Byron510 » 09 Nov 2009 07:03
There are P valves in the 240Z and the pick ups of this era, but the 510 did not get them.
htownsr510
Post by htownsr510 » 09 Nov 2009 15:47
so if i were to run completly new ss brake lines i could just eliminate this?
thisismatt
Post by thisismatt » 09 Nov 2009 17:17
Yup, off with its head
htownsr510
Post by htownsr510 » 09 Nov 2009 20:14
thanks
