200SX VG Strut Bump Steer Spacers- Completed
Here is the latest out of the Fast Guido Motorsport's workshop from the past week, bump steer spacers for the S12 200sx VG strut, that adapt to the stock 510 steering arm. 54mm on the top side for the larger bottom hole on the 200sx strut, 40mm hole on the bottom for the 510 steering arm. With a spacer height of 1.25". A nice big chunk of aluminum, just a little bit of de burring to do and then their done.
Monte
Monte
Re: 200SX VG Strut Bump Stop Spacer
You know, I think the only other guy to make these was Matt, and that was a few years ago.
What height did you make the spacer (note counting the centering spiggot)?
The spacer part is 1.25", the spigot is 0.25" in height.
How many are you making? I will be needing a set for my strut swap?
Monte, I've had a jig to place struts in the lathe for shortening since 1994, and many a strut have been modified in that jig (probably no less than 50 sturt sets, I kid you not!) Then a few years ago a guy here on the real asked if I could shorten his 200SX struts - no worries said I. Then I find the spigot on my jig is, as you stated, much too small! Simple fix, flip around that steel jig, and machine a 200SX spigot on the back side, uses the same threaded holes for fixation - and away we go!510wizard wrote:Here is the latest out of the Fast Guido Motorsport's workshop from the past week, bump stop spacers for the S12 200sx VG strut, that adapt to the stock 510 steering arm. 54mm on the top side for the larger bottom hole on the 200sx strut, 40mm hole on the bottom for the 510 steering arm.
I love your machine work, a man after my own machinist heart. Only you've got access to automated machinery. I still get by with the old hand cranks and a little uni-directions feed in one axis only type of machining We make it work.
Re: 200SX VG Strut Bump Steer Spacer
Price?
I might make some more if there is a demand. I will check about the material cost, I had this material already in the shop when I made this pair. Is Matt still making these?dscottdatsun wrote:How many are you making? I will be needing a set for my strut swap?
Thanks for the props. Yes, the Deckel CNC tool room mill has allowed me to do things, that would have taken a whole lot longer to do on the manual machines. This is especially true with the contours. The machine is extremely accurate, but isn't designed for production, just one or two offs.
Monte
if you can make a set 100 or less ill take a set
I will check on the material cost and be back in touch later.
Any further word, I would really be interested in a pair
Scott
Scott
Been super busy with other stuff, but thanks for kicking my butt in to gear. I will get the material price this week. One quick question, do you guys want me to source the bolts or leave it to you?
Monte
Monte
I can sorce my own bolts
Price on a pair of these spacers is $87.00 shipped by USPS priority mail. I can make them in either 1.25" ,1.125" or 1.00" spacer height with a .25" high spigot. If you want to pay by Pay Pal then add 3 %. After I get commitments on how many people want them, I will then order the material. I will then collect the money after they are completed.
Monte
Monte
Re: 200SX VG Strut Bump Steer Spacer- Now taking orders
I would like a pair! Please! (Mama told me to always use my manners) How much difference does the height of the spacer make? IIRC the NISMO spacer was an inch, so I'll go with that. I am not looking to put my ride on the floor.
Scott
Scott
