well i was just plannign ahead.okayfine wrote:A 15x6 rim with -12 will fit under stock fenders F/R. That was a 280ZX swastika rim, but you can extrapolate the math from that if you have to have 15x7. A couple good posts here from Dave Patten regarding 15" rim fitment as well.
Also keep in mind that a 510-suspension wheel fitment will not work if/when you change to ZX front struts unless you use different hubs, or spacers.
you should always have a plan.
thanks for the heads up. hadn't thought about that.
