control arm mono-balls
68 Wagon
Post by 68 Wagon » 20 Sep 2013 12:12
Any reason we can't use high misalignment mono-balls like the ones available from UB Machine in our rear control arms whilst lowering our cars? I plan on using Byron's rear kit when I do this.
S15DET
Re: control arm mono-balls
Post by S15DET » 20 Sep 2013 12:33
No reason, spherical bearings are commonly used at suspension pivot points. Search for opinions on the increased NVH, same feel it's
not bad, others say it's not streetable. Check out these RX-7 bushed-bearings for a unique option...
http://www.the510realm.com/viewtopic.ph ... g&start=15
Post by Byron510 » 20 Sep 2013 20:43
I've found the additional NVH induced from hiem joint or rod end joints or bearings on their own do not add excessive amounts on their own. But when seeking take the rubber out of the front suspension (camber plates and TC kits), and remove the rubber isolation from the rear (above the springs and solid mount the cross member ), it all starts to add up.
However the advantages of using monoball bushes in the rear suspension are so many, that I would certainly encourage anyone wanting good handling to do this modification on its own. Not only does it stop the binding designed into our suspension system, it takes a good portion of that rear steer tenancy out of the system as well. A very worthwhile mod for any 510, whether utilizing an adjustable system or not.
68 Wagon
Post by 68 Wagon » 21 Sep 2013 01:15
Thanks for the link S15DET and thanks Byron for your input. I will do it and let you guys know how it went.
