Konig Rewind brake clearance (answered)
Techromancer
Post by Techromancer » 23 Oct 2013 10:13
I'm looking to get some 15x7 +0 Konig Rewinds and I wanted to make sure that they would fit over my brakes. Does anyone have a set that wouldn't mind measuring one of their wheels? I've tried looking around the forums and didn't see any info.
For reference:
I have Wilwood brakes up front (don't have the part number on hand but they're 4 piston).
I have Rota Grid V 15x8 +0 wheels that clear the brakes no problem.
Re: Konig Rewind brake clearance (anyone mind measuring whee
Post by okayfine » 23 Oct 2013 10:28
Helpful to suggest what you'd like measured, at least the rotor size you have (if not the part number), or where you think you might have problems.
Techromancer
Post by Techromancer » 23 Oct 2013 12:18
It's an Aimco 1013243 rotor, 11.25" with a Wilwood Dynalite caliper. I'm just worried about the spokes clearing the caliper, so the inner profile of the spoke is all that matters.
johnbureezu
Post by johnbureezu » 23 Oct 2013 14:16
I have 15x7 0 offset rewinds and wilwood dynalites on 12"+ rotors and they clear just fine. Close but they fit. Just watch where you place the stick on wheel weights. I'm also using the .81" thick rotor.
Techromancer
Post by Techromancer » 24 Oct 2013 14:52
Awesome, thanks so much.
