Koni vs Tokico
tr6racer21
Koni vs Tokico
Post by tr6racer21 » 25 Jan 2014 19:04
working on setting up the Vintage race car front suspension. i was looking for some opinions on (2) possible shock setups. i have the option of using either Koni yellow adjustable inserts or the Tokico Illumimas. The Koni's have larger shaft diameter as a note....any thoughts...thanks
Re: Koni vs Tokico
Post by defdes » 25 Jan 2014 19:32
The Tolkico's are NLA until, from what I have hear d from 2 distributors, April or May. I am looking for the part numbers for a good adjustable (Koni or other) insert that doesn't cost $250/per like the race inserts do.
Check the "Suspension Setups" thread, good for info though light on part numbers.
Re: Koni vs Tokico
Post by defdes » 26 Jan 2014 05:00
If you are looking for Koni fitment, this is a good chart: http://performanceshock.com/KONI_86_series_race.pdf
