280ZX Front Wheel Bearings
Post by defdes » 02 Feb 2014 11:07
I am changing these out and having a difficult time finding the inner wheel bearings and the inside "collar o-ring" for the seal.
They are Timken numbers LMG7010 (inner race) LMG7048 (inner bearing) LM1190 (outer bearing w/ race, easily found) 48-62-8 / 18962 (oil seal).
Does anyone else have some more viable numbers?
*EDIT:*
Just found these as Timken "SET6" inner, and Timken "SET2" outer (apparently it was LM6 NOT LMG), but still no luck on that funky oil ring inner seal.
qwik510
Re: 280ZX Front Wheel Bearings
Post by qwik510 » 02 Feb 2014 11:31
Enjoy The Ride!
David
Post by defdes » 02 Feb 2014 11:42
Ahhh, thanks, no I hadn't. I was looking for a steel one like the one that I removed, but those oughta' work too.
Thanks again.
Post by goichi1 » 10 Mar 2014 14:13
The bearing should come with the race as a set
Post by defdes » 10 Mar 2014 15:01
Got them in, thanks. TIMKEN Set2 outer, Set6 inner.
