spacer source
dodgydan
spacer source
Post by dodgydan » 27 Feb 2014 15:15
im looking for supplier of 10mm 4x114.3 spacers. all I can find are cast univ. or ones with 66mm or smaller center bore. no good for 280zx's 73.1mm Cb. tried emailing (spec' eng') but assume they are swamped, cause of no response. any ideas :?:
Mattndew76
Re: spacer source
Post by Mattndew76 » 27 Feb 2014 15:53
The realm has a few machinists that post here and there. One of them could help you out ;)
Send me a PM
Re: spacer source
Post by defdes » 27 Feb 2014 15:55
Ash510
Re: spacer source
Post by Ash510 » 27 Feb 2014 19:47
I think Dave Patton has them at Futo Fab give that a search.
good luck.. Aron
dodgydan
Re: spacer source
Post by dodgydan » 27 Feb 2014 20:27
ya dave I think has 3mm and 8mm. im looking for 10mm. need to get more clearance from the strut tube. ill keep hunting.
I did send motorsport-tech an email with specs. thanks for the link.
man it feels good to get back onto the datsuns again.
Re: spacer source
Post by James » 27 Feb 2014 21:58
Matt was offering to make you a set - I'm sure he could handle it…..
dp61
Re: spacer source
Post by dp61 » 27 Feb 2014 22:06
There is an import shop on Bridgeport in Richmond that I am sure had these last summer, if they don't still they can bring them in from Japan. PM me and I'll try to get you their address this weekend if you want....
Re: spacer source
Post by funwithmonkeys » 28 Feb 2014 08:49
I got them off Ebay. They arrived in 7 days and came with new studs.
dodgydan
Re: spacer source
Post by dodgydan » 28 Feb 2014 11:14
James wrote:Matt was offering to make you a set - I'm sure he could handle it…..
yep, thanks. sent him a pm.
Mattndew76
Re: spacer source
Post by Mattndew76 » 28 Feb 2014 11:48
I am always up for making custom stuff for the Datsun.
Do you want a location boss?
dodgydan
Re: spacer source
Post by dodgydan » 28 Feb 2014 17:11
:?: not sure what you mean by "location boss"
do you mean like an alignment dowel or something. to index?
Mattndew76
Re: spacer source
Post by Mattndew76 » 28 Feb 2014 18:20
Location boss would be material that fits into the center hub of the wheel to keep the spacer concentric to rotation.
dodgydan
Re: spacer source
Post by dodgydan » 28 Feb 2014 18:59
oh hubcentric. no point in a location boss cause the rear hub/rotor set up is flush, and the wheels have tapered lug holes.
and that centers the wheels fine.
Mattndew76
Re: spacer source
Post by Mattndew76 » 28 Feb 2014 19:56
Sounds good. Just had to make certain :)
Mattndew76
Re: spacer source
Post by Mattndew76 » 03 Mar 2014 17:10
Anyone else needs wheel spacers?
I'm gonna order enough material for a few ;)
