The Datsun 510 Wheel and Tire FAQ
1984 Nissan 200SX
Post by okayfine » 31 Mar 2014 13:43
Wheel Size and Type: 14x5.5
Source/Brand: OEM, Nissan #40300-F5327, Hollander #62131
Offset / Backspacing: BS = 113mm or 4.45", OS = +30mm
Weight: 15lb
Tire Size: 185/70-14 185/60-14 195/60-14 205/60-14
Notes or 510 Mods Needed: Large hexagonal centercap. Must use Nissan lug nuts!
1980-1983 Datsun 200SX
Post by okayfine » 31 Mar 2014 13:45
Source/Brand: OEM, Nissan #40300-11S25, Hollander #62130
Offset / Backspacing: BS = 109mm or 4.25", OS = +25mm
Weight: 15lb
Notes or 510 Mods Needed: 16-spoked turbine wheel with small centercap with 'D' on it. Must use Nissan lug nuts!
Post by okayfine » 31 Mar 2014 13:46
Source/Brand: OEM, Nissan #40300-N8427, Hollander #62134
Offset / Backspacing: BS = 111mm or 4.37", OS = +28mm
Weight: 16lb
Notes or 510 Mods Needed: 32-spoked turbine wheel with small centercap with 'D' on it. Must use Nissan lug nuts!
Post by okayfine » 31 Mar 2014 13:48
Source/Brand: OEM, Nissan #99990-00918, Hollander #62160
Offset / Backspacing: BS = 107mm or 4.21", OS = +24mm
Weight: 14lb
Notes or 510 Mods Needed: Flat disk wheel with black machined slots in plus sign shape. Must use Nissan lug nuts!
1982-1985 Toyota Celica/Supra/Van
Post by okayfine » 31 Mar 2014 13:50
Source/Brand: OEM, Toyota #42601-14012, 42601-12101, Hollander #69145
Weight: 14lb
Notes or 510 Mods Needed: Silver and black cast wheel, 4 black insets look like a plus sign.
1985-1987 Toyota Van/Cressida/Corolla
Post by okayfine » 31 Mar 2014 13:51
Source/Brand: OEM, Toyota #42611-12790, Hollander #69274
Offset / Backspacing: BS = 110mm or 4.33", OS = +27mm
Weight: 14.5lb
Notes or 510 Mods Needed: Cast 8-pointed star, each point made of 4 spokes.
1987-1990 Toyota Van (2WD)
Post by okayfine » 31 Mar 2014 13:53
Source/Brand: OEM, Toyota #42611-28140, Hollander #69275
Weight: 17lb
Notes or 510 Mods Needed: Cast dish wheel with 9 short spokes at edge.
1979-1980 Datsun 280Z (Iron Cross)
Post by okayfine » 31 Mar 2014 13:55
Wheel Size and Type: 14x6
Source/Brand: OEM
Offset / Backspacing: BS = 102mm or 4", OS = +13mm
Weight: 18/lb
Tire Size: 195/60-14 205/60-14
Notes or 510 Mods Needed: Looks like Iron Cross. One-piece cast, heavy (great for rally). Must use Nissan lug nuts!
1981-1983 Datsun 280ZX
Post by okayfine » 31 Mar 2014 13:57
Source/Brand: OEM, Nissan #40300-P8185/6, Hollander #62146
Offset / Backspacing: BS = 101mm or 3.98", OS = +12mm
Weight: 13lb
Notes or 510 Mods Needed: Popular 510 wheel, 6-pointed star. LIGHT 2-pc wheel. Must use Nissan lug nuts!
Panasport FS14
Post by okayfine » 31 Mar 2014 13:59
Source/Brand: Panasport/FS14 (240Z fitment)
Offset / Backspacing: OS = +15mm
Weight: 13lb
Notes or 510 Mods Needed: 8 spoke lightweight cast wheel. Uses tapered lug nuts.
1983-1985 Mitsubishi Starion/Dodge Conquest
Post by okayfine » 31 Mar 2014 14:02
Source/Brand: OEM, Dodge #MB150057, Hollander #65631
Offset / Backspacing: BS = 108mm or 4.25", OS = +19mm
Weight: 15lb
Notes or 510 Mods Needed: 8-pointed star. One-pc cast wheel.
American Racing AR24
Post by okayfine » 31 Mar 2014 14:05
Source/Brand: American Racing/AR24
Offset / Backspacing: OS = +35mm, BS = 4-13/16"
Weight: ?
Notes or 510 Mods Needed: Flower-petal cut-outs. One-pc cast wheel, very inexpensive. Used on Tim Bridge's 2dr 510 wagon. Needs spacers ??
TSW Quad
Post by okayfine » 31 Mar 2014 14:07
Source/Brand: TSW/Quad
Offset / Backspacing: OS = +10 to +40mm
Weight: ?
Notes or 510 Mods Needed: 8 spoke wheel, looks like a plus sign. One-pc cast wheel. Also available in 15" x 6.5".
Panasport FS14 (Race Only)
Post by okayfine » 31 Mar 2014 14:09
Wheel Size and Type: 14x7
Offset / Backspacing: OS = 0
Weight: 10.5lb
Notes or 510 Mods Needed: 8 spoke lightweight cast wheel. These wheels are race only, as they are not DOT approved as they have a thinner rim section. Uses tapered lug nuts. Will not accept center caps. Must have flared fenders.
1982-1985 Toyota Supra/Celica GTS
Post by okayfine » 31 Mar 2014 14:12
Wheel Size and Type: 14x7 or 15x6
Source/Brand: OEM, Toyota #42601.14021, Hollander #69144
Offset / Backspacing: BS = 110mm or 4.33", OS = +8mm (OS=+21 for 15")
Weight: 14lb
Notes or 510 Mods Needed: 1-pc cast wheel, looks like plus sign. Wheel incorrectly says 14 x 8 on inside. Also came in 15" x 6". Uses tapered lug nuts.
