The Datsun 510 Wheel and Tire FAQ
1982-1982 Datsun 280ZX Turbo (Swastika)
Wheel Size and Type: 15x6
Source/Brand: OEM, Nissan #40300-P9525/6, Hollander #62140
Offset / Backspacing: BS = 101mm or 3.98", OS = +12mm
Weight: 14lb
Tire Size: 195/50-15 205/50-15
Notes or 510 Mods Needed: Light, 2-pc wheel, must use Nissan lug nuts! Fits stock unrolled fenders with 195 tires.
Weight: 14lb
1981.5 Datsun 280ZX Turbo (Snowflake)
Source/Brand: OEM, Nissan #40300-P9000
Weight: 17lb
Notes or 510 Mods Needed: 8-pointed snowflake, hard to find, heavier wheel.
Weight: 17lb
1984-1987 Nissan 200SX
Source/Brand: OEM, Nissan #40300-18F27/40300-22F25, Hollander #62132/62164
Offset / Backspacing: BS = 126mm or 4.96", OS = +37mm
Weight: 19lb
Tire Size:
Notes or 510 Mods Needed: 8-pointed snowflake. Need to use .5 - .75 inch wheel spacers. Must use Nissan lug nuts!
Weight: 19lb
Tire Size:
1985-1986 Nissan 200SX Turbo
Source/Brand: OEM, Nissan #40300-F6029, Hollander #62133
Offset / Backspacing: BS = 121mm or 4.76", OS = +32mm
Weight: 19lb
Notes or 510 Mods Needed: 16-pointed snowflake. Need to use .5 - .75 inch wheel spacers. Must use Nissan lug nuts!
Weight: 19lb
1985-1986 Nissan Maxima
Source/Brand: OEM, Nissan #40300-13E85, Hollander #62198
Offset / Backspacing: BS = 134mm or 5.27", OS = +45mm
Weight: 20lb
Notes or 510 Mods Needed: HEAVY flat disk wheel with rectangular slots around outside edge and rectangular indents on face. Must use Nissan lug nuts!
Weight: 20lb
1987-1988 Nissan Maxima
Source/Brand: OEM, Nissan #40300-38E28, Hollander #62271 (#62223 for tapered lug nuts)
Offset / Backspacing: BS = 133mm or 5.24", OS = +44mm
Weight: 17lb
Notes or 510 Mods Needed: Flat disk wheel with rectangular slots around outside edge and flat face. Need spacers. Must use Nissan lug nuts!
Weight: 17lb
1989-1990 Nissan 240SX
Source/Brand: OEM, Nissan #40300-40F25, Hollander #62255
Offset / Backspacing: BS = 130mm or 5.12", OS = +41mm
Weight: 16lb
Notes or 510 Mods Needed: 12 teardrop holes around outside face. May need spacers. Tapered lug nuts.
Weight: 16lb
1991-1994 Nissan 240SX
Source/Brand: OEM, Nissan #40300-53F25, Hollander #62287
Weight: 18lb
Notes or 510 Mods Needed: 7-pointed star, flat face. May need spacers. Tapered lug nuts.
Weight: 18lb
1995-1996 Nissan 240SX
Source/Brand: OEM, Nissan #40300-53F25, Hollander #62315
Weight: 15lb
Notes or 510 Mods Needed: 7-pointed snowflake design. May need spacers & tapered lug nuts.
Weight: 15lb
1984-1985 Nissan 300ZX
Wheel Size and Type: 15x6.5
Source/Brand: OEM, Nissan #40300-04P25, Hollander #62151
Offset / Backspacing: BS = 126mm or 4.96", OS = +31mm
Weight: 19lb
Tire Size: 195/50/15
Notes or 510 Mods Needed: May need .25" to .75" spacer to clear strut. Heavy cast wheel. Must use Nissan lug nuts!
Weight: 19lb
Team Dynamics Hockenheim
Wheel Size and Type: 15x7
Source/Brand: Team Dynamics/Hockenheim
Offset / Backspacing: OS = +18mm
Weight: 17lb
Tire Size: 205/50/15
Notes or 510 Mods Needed: Basket-weave look. One -pc cast wheel, needed 1/4" spacers to clear 280ZX front struts. Should clear stock front struts w/o spacer.
Weight: 17lb
- shill2b.jpg (50.99 KiB) Viewed 4999 times
Ronal R10 Turbo
Source/Brand: Ronal/R10 Turbo
Offset / Backspacing: OS = -20mm
Weight: ?
Notes or 510 Mods Needed: 1/2" wheel spacers on front.
Weight: ?
- ronal.jpg (40.75 KiB) Viewed 4999 times
OPEN For Business
I have posted up the wheels from the "known to fit" category of the wheel FAQ. There was also a section of "could possibly fit" wheels, but I want to keep this to wheels known to fit the 510. If you have additional information or corrections for any of the wheels listed, including updated/bigger pictures (specifically pictures of the wheels on actual 510s), please let me know. I will be happy to add/update individual wheel posts for those wheels posted before this post.
Now...it's up to all of us at The Realm to fill in the wheels we have personally used on our 510s.
Since that can involve a wide range of wheels, suspension parts, ride heights, etc., I'd also like to propose this format, similar to what was originally used by Kurt:
Post Subject: Change the subject line of your post to match the brand/model of your rim.
Wheel Size: - Keep this as a 15x7 (nnxn) format so people can search 15x7 since The Realm search won't allow '15 x 7' being it is too short.
Source/Brand: - Brand and model are more important than source, since Google allows much easier searching than we had back in the day. However, the source you used and the price you paid, if bought new, would be useful information.
Offset / Backspacing: Very important, for obvious reasons.
Weight: Self evident.
Tire Size: Please list the tire make/model and size that you used with the rim you are adding. Tire widths vary across manufacturers for a given size, but with that information anyone can look up the vital measurements.
Notes or 510 Mods Needed: The most important part of your submission. Here, please detail your suspension setup (stock struts, 280ZX front struts, S12 struts, etc.), ride height (measured at the front and rear rocker flat to ground), body modifications (rolled fenders, minitub, flares, etc.), and any other modifications necessary (notched rear a-arms) that are required to fit these wheels to another 510.
Pictures are also very welcome; wheel-only and/or side profiles work well.
