JFZ / Willwood brakes on yoAr 510 Strut assembly
jaredperry
Postby jaredperry » 22 Sep 2014 22:58
Do you want to upgrade your brakes without purchasing bigger wheels?
Do you want to retain your 13” wheels?
Do you want to keep your 510 strut assemblies?
No problem!!
This Stainless Steel adapter will fit to your stock 510-strut assembly without modification. You can even retain your OEM 17mm mounting bolts if you wish.
The 3/8” Stainless, CNC’d adapters have custom spacers TIG welded to the assembly. The adapter is a direct bolt on using Grade 8 hardware and self locking nuts.
The Rotors are also available if desired. The vented rotors are machined to fit the 510 OEM Spindle.
Please inquire for pricing or if there are any further questions.
510tsunami
Re: JFZ / Willwood brakes on yoAr 510 Strut assembly
Postby 510tsunami » 18 Mar 2017 16:25
Hi, I'm interested in finding out if the disc brake kit is still available. I have threaded struts but the rest is pure stock with 13" wheels and tires. If available could you provide a price? If they are no longer available would you know of another source that I would be able to contact?
Thanks
Return to “Suspension”
Users browsing this forum: GREG510 and 4 guests
