KA24de sway bar question
rdanard
Post by rdanard » 11 Aug 2015 13:57
I'm just finishing a KA24de swap and need a sway bar for the front. I see futofab has some for a front sump car, would that fit my application? I have tried to Email the guys at futofab with no reply so i thought i would ask you guys :D Thanks Ryan
Re: KA24de sway bar question
Post by RONSLYCHUK » 11 Aug 2015 14:39
You can also try Speciality Engineering in Vancouver.
rdanard
Post by rdanard » 11 Aug 2015 15:45
Thanks, I'll give them a shot.
finn
Post by finn » 11 Aug 2015 18:05
I have the front sump sway bar from fotofab. Cleared the pan no problem.
'69 2dr KA24DET
rdanard
Post by rdanard » 13 Aug 2015 06:58
Thanks Finn
Dave Patten
Post by Dave Patten » 14 Aug 2015 08:13
Ryan,
I got an email from you on July 18th and replied the same day. Looks like your spam folder may have eaten it.
Anyway here was my reply.
Ryan,
With a KA24, the sump is forward of the crossmember. Our front sump bar should work. It will depend on how the cross member was modified. Most flipped cross members have the center section is cut out, reversed and re-welded in place with the bend to the rear for room for the sump. I've had customers have difficulties with how some of their cross members were modified, but generally if the cuts for the flip are made no more than 1/2' to the inside of the motor mounts you are good.
Dave Patten
http://www.FutoFab.com
Dunbarton, NH
rdanard
Post by rdanard » 17 Aug 2015 20:47
Thanks for the reply... Your usually quick with your replys I found it weird I didn't hear back from you. Thanks Dave
