Front wheel bearing torque for racing
I was just wondering what you racing guys use for front wheel bearing torque strictly for racing purposes. I have been running my car for a few years, and have had pad kickback issues with these front bearings (280zx). It seems to get worse the hotter the brakes get. I have tried torqueing the bearing a little tighter which help a little, but I don't want to get crazy with the bearing torque and cause a failure. I also understand that when you tighten the bearing preload, you will essentially shorten the life of the bearings, but my car mainly sees the track, so replacing bearing every once in a while is not a big deal. I currently have the bearings set to just slightly over hand tight. Stock is 25ftlbs then back it off 60*, which makes it just about hand tight.
To combat the issue of heat causing the kickback issues, I have upgraded to a 2 piece rotor. That should take quite a bit of heat out of the hubs to reduce the kickback, but now my rotors are 12.2" vs 10.8", so the kickback will be increased from the rotor size, but maybe the heat will counteract the kickback. I was going to try torqueing the wheel bearings tighter to see if some of the kickback goes away.
First step is just to replace the races and bearings, but I doubt that will do anything...
Re: Front wheel bearing torque for racing
Bearing torque is critical. Too tight and all you're doing is squeezing the crap out of the inner/outer parts of the bearing making them fail sooner, and increasing rolling friction. Maybe you have crappy chinese bearings?
There is a circle track supply company that makes a spacer that goes between the inner and outer race that allows you to torque them up and keep rolling friction at a minimum. Someone on hybridz found they have one that fits the 240/280z hubs. No clue if the 280zx spindle/bearing spacing is the same. I'll see if I can find that link for you.
Aha!
http://forums.hybridz.org/topic/122454- ... try1145230
The discussion begins with sourcing highest quality bearings, then leads into the need for a spacer to allow proper torquing.
DRP Performance is the source.
http://store.drpperformance.com/bearing-spacers/
Aha!
Very good information. I looked up the legends bearing spacer and confirmed the measurements, so it looks like it will work. I do use good quality bearings, but taper bearings seem to always have some runout even when they are preloaded... Thanks for the info zKars!
http://store.drpperformance.com/bearing ... ble-steel/
I love the idea of this spacer, wish I had thought of it. Please let us know if it works for the 280ZX spindle/bearings.
The Z cars use the same wheel bearings as the 280zx, so I would assume so. I am going to get a new set of bearing and see if I can grab set of spacers soon.
Morning Gang,
I fought this also. I tighten my bearings pretty snugly too, never checked the torque thought, just get it finger tight, then give it a bit of a turn tighter on the crescent wrench. Seems to work fairly well, with minimal pad knock back .
One thing I do do, is keep my pads square ( flat) Andy made a jig for a dedicated belt sander, to true up the pads, works like a hot damn, keeps taper wear to a minimum.
What calipers do you run? I eliminated 90% of my perceived knock back when I went to the forged caliper, flex was gone, as that was my biggest issue with the old JFZ/WILWOOD Mini GN calipers.
Here is a picture of my brake cooling duct, which properly blows air into the center of the rotor.
- IMG_2524.JPG (172.3 KiB) Viewed 5760 times
- hose attachment.JPG (172.8 KiB) Viewed 5760 times
- bend in sway bar.JPG (170.91 KiB) Viewed 5760 times
- aircraft duct hose.JPG (155.41 KiB) Viewed 5760 times
- 280zx cooling duct.JPG (171.68 KiB) Viewed 5760 times
The aluminium face sits a few thou' off the rotor edge.
- IMG_7973.JPG (115.4 KiB) Viewed 5759 times
Thanks for the suggestions. With the addition on the 2 piece rotors, i have also changed from the old style wilwood dynalites to the new dyna-pro, which is a forged billet caliper with a bridge bolt to decrease caliper flex. I also have brake ducts that blow air to the hat area of the rotor, then the curved vane rotor pulls the air the rest of the way through. I will replace the front bearing and races next week and set where that gets me.
I also set the bearings to slightly tighter than hand tight, but it didn't help much with the play.
Thanks for the info again!!
I hear yah, I will ask Andy at Specialty about the bearing spacer, I seem to remember he did something like that for the GT3 cars. I know we did have a discussion about pad knock back, it is after all one of the MOST annoying things a racer deals with. The "comfort" tap on the brake just becomes so standard, I do it on all my cars.
Thanks for asking. I am used to doing the love tap before each corner just to make sure the pedal is at the highest spot, but on 2 of our tracks we have a small chicane into a braking zone which really is hairy when coming in hot and left foot braking to keep the pedal high... And don't say just go slower, because that's not going to happen!
Cold day in hell when I say go slower......
I will be going by Specialty on the way home tonight.
So, this is Andy's take.
He makes his own basically, torquing the wheel bearing till it is close, then machining off whatever is needed get to the to the proper torque. Or, uses a shim.
He says they work quite well if installed properly.
I do know that any of Andy's race cars have impeccable brakes.
- funwithmonkeys
It makes me happy that Andy is doing the brakes on mine.
When is your car going into Andy's?
- funwithmonkeys
He already has it, work should be starting this week on it as I understand. It is in the hanger next door hanging out with the helicopters till he starts on it.
