Camber plates-- adapting 5/8 bearing for 12mm strut-shaft?
SteveEdmonton
Postby SteveEdmonton » 13 Mar 2016 19:19
Hi all;
I picked up a set of DP Racing camber plates a year and a half ago through this site. Good deal on what seems to be a good product-- I was happy. Now that I'm finally preparing to use them, though, I discover a problem that's got me stumped.
The spherical bearing in the camber plate is 5/8 ID. That's the only way DPR makes them (http://www.dpracing.co/#!datsun-510-fro ... ion-1/cdht). That's probably why I never thought anything of it when I bought these plates. A 5/8 bearing just seemed to be the normal setup.
It took all of two seconds though when I held them up to my 280ZX strut cartridges the other day (KYB cartridges-- also bought used here, from Norm) (thanks again!) to realize this just ain't gonna work. I haven't done exhaustive research but a bit of poking around suggests that the "standard" Datsun/Nissan strut cartridge threading is 12mm. And further, that 12mm part of the shaft has a "D" profile-- flattened on one side-- in order to hold the shaft from turning when you're threading the nut on or off.
First thought: I'll just change the bearing. According to McMaster Carr, a 12mm ID spherical bearing is readily available. However, that bearing's 30mm OD doesn't fit into the 1 3/16 inch socket in DPR's camber plate. Swapping an ID problem for an OD problem doesn't get me anywhere. :?
My second idea: A piece of 5/8 OD steel pipe with a wall at least 2mm thick (a bit more than 1/16 inch) could be turned down (or maybe even filed down?) to achieve a 12mm ID. Pop that insert into the current 5/8 bearing and the strut shaft would at least fit snugly in terms of lateral movement.
But I'd still have two remaining problems. (1) No "D" feature to hold the strut shaft from turning. Having fought with Hyundai strut cartridges on my son's car that lacked such a feature, I am convinced that this "D" profile is a Very Good Idea indeed.
(2) Even if I solve that problem, the ball of this 5/8 spherical bearing is so TALL (19mm) that only 6mm of the threaded part of the strut shaft projects above it. The nut that goes onto that shaft requires 10mm of threading to be fully engaged. And that's without the Nyloc portion of the threading, which adds another 2mm or so. Ideally the strut shaft should project at least 12mm above the bearing-- that is, a full 6 mm more than the height of this 5/8 bearing allows for. Because the 12mm ID bearing that McMaster Carr offers is only 16mm tall, going that route would gain me 3mm overall-- which would maybe be minimally acceptable. But then I'd be back to the problem that its OD doesn't work, nor does it have a "D" profile....
Ideas?
'71 4-door
'74 MGB-GT
'04 Miata
Chickenman
Re: Camber plates-- adapting 5/8 bearing for 12mm strut-shaft?
Postby Chickenman » 13 Mar 2016 19:46
The shock absorber normally has a machined shoulder that fits inside the spherical ball bearing. Then the threaded section necks down. You use a 12mm ID flat washer under the nut of course.
A reducer bushing should be included in the kit to fit common shocks. Don't worry about the " D " flat. Bang the Nyloc nut on with an Impact ( I know, I know... but it's done all the time with no ill effects ), use a regular nut with a half height Jam nut or two half height jam nuts.
Below is a picture of a Typical KYB shock. I'll go down and measure the shaft diameter on my 280Z Tokico HP shocks after dinner. Pretty sure that the shaft diameter is BIGGER than 12mm by a long shot. 280Z and ZX shaft diameter should be the same.
Picture showing typical machined shoulder that should fit into bearing. A bushing reducer is normally used on this part if needed. Shoulder can be machined deeper if needed to expose more thread.
Postby funwithmonkeys » 13 Mar 2016 19:47
Bring them to a machine shop and get them to turn a section below the thread down to the diameter you need. That is probably the simplest. That is what was done on the new inserts that I have. Less bits involved and you have lots of thread for the nylock nut.
SteveEdmonton
Postby SteveEdmonton » 14 Mar 2016 07:56
Very helpful guys, thanks. Somehow I missed this part about needing to have the shoulder turned down, in reading about this conversion process. Wish it was something I could do myself, but oh well. "Support your local machinist," right?
'71 4-door
'74 MGB-GT
'04 Miata
Return to “Suspension”
