Offset question
lovememydatsun
Offset question
Postby lovememydatsun » 02 Apr 2016 17:22
I have a question fellas, would a 15 by 6.5 plus 18 offset tuck under the 510 fender?? Or would the tires stick out? Thanks.
Dave Patten
Re: Offset question
Postby Dave Patten » 03 Apr 2016 10:12
It should fit fine with 195/50 tires, no problems unless you have 280ZX front struts.
With the ZX struts you may have tire/strut tube clearance issues.
And they definately will not stick out.
Dave Patten
http://www.FutoFab.com
Dunbarton, NH
lovememydatsun
Re: Offset question
Postby lovememydatsun » 03 Apr 2016 14:34
Dave Patten wrote:It should fit fine with 195/50 tires, no problems unless you have 280ZX front struts.
Thanks for the reply. And I plan on putting zx struts,
Return to “Suspension”
Users browsing this forum: Tedman and 1 guest
