help ID front struts
510llama
Post by 510llama » 06 Aug 2016 23:28
was told these are 280zx struts but I am starting to have my doubts...
I wanted to get 280zx struts to bring the wheels in and have better brakes. thanks for any help
Re: help ID front struts
Post by okayfine » 07 Aug 2016 14:27
Yeah, that's what 280ZX struts look like. Why are you suspicious?
510llama
Post by 510llama » 07 Aug 2016 20:52
okayfine wrote:Yeah, that's what 280ZX struts look like. Why are you suspicious?
the hubs on all the 280zx strut pictures i've seen are a full circle. these ones have the cutouts on it that are similar to the 510 ones i already have. just made think that maybe they are from a 710 or something.
Post by okayfine » 08 Aug 2016 05:49
I don't recall 710 stuff being vented disc. Looks like the ZX caliper (boat anchor).
My old ZX stuff didn't have a full-circle hub face, but it did have a rounded square face, and not cutouts as shown above. However the hub offset looks right for ZX (as in, minimal). You could measure the rotors. ZX is 9.9" dia.
toylet
Post by toylet » 08 Aug 2016 21:53
510llama
Post by 510llama » 09 Aug 2016 12:34
510llama
Post by 510llama » 06 Sep 2016 19:28
ok after doing the research i have found out that these seem to be 83-84 maxima struts. my main concern is the spindle angle being the same as 280zx struts. can anyone confirm this 100%? i want to make sure before i start ordering coilovers and things to do the conversion. thanks
Post by okayfine » 07 Sep 2016 05:50
'83 Maxima struts should be the same as '83 ZX struts as far as dimensions. I have not done that swap using those parts, but the Strut Swap article in DQ says it works.
You could find the posts here where Byron shows strut angles, then compare with what you have.
