Help needed, T3 Coilovers and camber plates
back2klassic
Postby back2klassic » 21 Sep 2016 22:20
Alright, I may be over thinking this, but I'm having trouble setting up these coilovers and camber plates from T3.
First this is what I have to work with - Image
280zx front struts and KYB 280zx shock absorbers, T3 camber plates, top hats and coilovers.
and i do have more nylon lock nuts but only one of (Nut A in the picture).
I'm trying to figure out where to run the spacers (C,D,E) I know i only need one for each side, and whatever one i use, is the one I use for both. but does this go above the camber plates, or below slid onto the strut (which if i use any of them I cannot fit nut A)
What keeps the shock absorbed from flailing back and forth inside the camber plates?
Space between shock and camber plate hole
The only thing i can think of, would be to use the nut A in the first picture but I only have one.
And last, shouldnt the coilover be attached to the top of the shock absorber
like this persons
Image,
and not sitting half way, like mine
Thank you guys, After owning the car for a year, the car is about to run for the first time since 1999.
Re: Help needed, T3 Coilovers and camber plates
Postby funwithmonkeys » 22 Sep 2016 18:08
I had the same issue. You will need to get the strut insert turned down by a machine shop so that the treaded part sits above the camber Plate enough to get the nut on.
back2klassic
Postby back2klassic » 26 Sep 2016 00:42
I was able to get the insert to work with the camber plate nut that came with the setup, but they only supplied me with one. Anyone know how to get another one? Ive tried contacting T3 but they wont respond.
Similar to this (in first picture)
Postby Three B's Racing » 26 Sep 2016 04:55
back2klassic wrote:I was able to get the insert to work with the camber plate nut that came with the setup, but they only supplied me with one. Anyone know how to get another one? Ive tried contacting T3 but they wont respond.
Threaten to send everything back due to an incomplete kit that is rendering it useless, lack of communication and responce. Seems to always work for me when those times come a calling.
Colbino
Postby Colbino » 26 Sep 2016 08:31
Just call them up and let them know you were short changed one nut and they'll send you over one. I had a similar issue with them and they were fast to fix it.
back2klassic
Postby back2klassic » 26 Sep 2016 15:00
Forgot it was the weekend, and they've contacted me back now. Straitened everything out and they are sending the nut i need in the mail in the next couple of days.
That4doorKiD
Postby That4doorKiD » 26 Jan 2017 14:37
I bought camber plates also for my zx struts and coilovers. Do I need top hats with radial bearings? I don't understand why we need them and I do not have T3 plates.
thanks,
-Jacob
68 4doorFanatic
Postby okayfine » 26 Jan 2017 18:23
Stock 510 top hats have large bearings in them to ease steering. Needle bearing tops duplicate that for those with camber plates. In some camber plate configurations without the needle bearing tops, you're metal-on-metal when steering. That's not good.
Return to “Suspension”
