280ZX brake seals ?
Doraemon
280ZX brake seals ?
Postby Doraemon » 22 Nov 2016 14:06
Got my self some front 280ZX struts and brakes. Today got the time to take the brakes apart and sandblasted the brakes. They really look nice now and have to find my self some paint for them. But got some little questions.
All looked pretty well but only one piston looked a bit rough. Is it still ok ?
Did put it in a lathe and polished it a bit.
And anyone knows a good source for new rubber seals ? Seems here in Europe its hard to find :?
Re: 280ZX brake seals ?
Postby okayfine » 22 Nov 2016 17:01
Caliper kits look readily available State-side:
http://www.rockauto.com/en/catalog/niss ... r+kit,1720
Postby datzenmike » 23 Nov 2016 06:48
#41124 - P6500
Doraemon
Postby Doraemon » 23 Nov 2016 08:59
Thanks for the replies. Seems have to order in the USA.
Do you guys think the piston is still ok to use ?
Postby datzenmike » 23 Nov 2016 20:44
It's most important that the seal be tight fitting against the caliper casting and the casting be perfectly smooth. The piston just holds the seal and is less important, I think. It should be smooth and close fitting though. Is that pitting I see on the piston?
Doraemon
Postby Doraemon » 25 Nov 2016 12:16
Yeah there is some pitting. Probably will order a new piston since they only cost $9.
Return to “Suspension”
