Any shops in SoCal to tap/thread inside a strut?
That4doorKiD
Post by That4doorKiD » 17 Feb 2017 13:43
I'm ready to cut my zx struts and shorten them to a 92 MR2 rear shock. I live in the valley and so far no shops "can" do the job. I've seen people cut 2-3 inches of the middle portion of the strut and weld back the top to the rest of the it, so you wouldn't have to cut off the threads.
Anyone familiar with similar ideas? And I do not want to buy a steel collar and weld it to the strut.
68 4doorFanatic
Re: Any shops in SoCal to tap/thread inside a strut?
Post by okayfine » 17 Feb 2017 17:27
DQ Volume 6 Issue 3 - Strut Shortening and Economical Ride Height Adjustment: Suspension travel is always at a premium on a lowered 510. You want to get the center of gravity as low as possible for better handling and that cool racer look. Suspension travel is essential to good handling and grip. Shortening the strut helps restore some of the lost travel on a lowered 510. More available travel = more available grip = better handling. With this modification to your stock struts (or any strut housing longer than 280ZX) you will get up to 1-3/4" of extra suspension travel and as a side benefit end up with adjustable front ride height.
That4doorKiD
Post by That4doorKiD » 18 Feb 2017 12:17
Oh?
68 4doorFanatic
