Difference between 610 and 510 rear sub frame
zKars
Post by zKars » 14 Apr 2017 18:44
Hey gang, I have a chance to pick up a cheap rear sub-frame from a early 70's 610. I plan on welding on a set camber adjusters to this "spare" sub frame to keep the time my 69 510 would be down to a minimum. I'm fairly sure they are the "same" at least design wise, but is there something dimensionally or otherwise that anyone knows for sure that would make it an impossible piece to use?
Re: Difference between 610 and 510 rear sub frame
Post by datzenmike » 14 Apr 2017 20:31
I think the 610 has very slightly wider spacing for the control arms.
zKars
Post by zKars » 15 Apr 2017 06:56
Thanks Mike. I'll have the seller do some careful measuring before I commit. I am removing the stock control arm mounting flanges and welding on the new, so that might not matter. Probably better to hunt down a 510 sub frame.
Post by Byron510 » 15 Apr 2017 07:45
I know that the front control arms were slightly longer that the 510 ones. For rally guys, the 610 control arms were valued when cars sat at higher ride heights in order to keep some positive camber.
I know that the rear X members were interchangeable with the 510, only because a friend in high school did swap out his complete 610 rear x member and control arms with diff and half shafts and installed it inot his 510. But that's nearly hear say, as I was not involved, and just know it was done without issues.
That's about all I can assist you with Jim. maybe someone else out there can chime in.
