Adjustable Rear Spring Perch
jeffball610
Postby jeffball610 » 30 May 2017 17:01
I'm having trouble finding any info on spring perches for the stock rear 510 location. I know someone has done it, but I can't even find good info on spring size. From what I can gather, the stock rear springs are about 4.25" OD and about 3" ID. The suspension kit I ordered 10 years ago from Top End Performance is no longer available, but works pretty well so far. I need to adjust the rear just a bit due to my Z31 spindle swap I did.
I've searched for perches, but info seems thin from what I've done so far. There are some kits for 5" springs and lots for the common 2.5" springs most of us run on the front struts. Does anyone have a decent source in the states? I'm trying to get this resolved before this weekend 6/3/17 so I can make the most of my first autocross event in the car.
1972 Datsun 510
7-bolt 4G63T, EVO 9 pistons & rods, Garrett GT3076R, "Flipped" Stock Intake Manifold, Toyota R154, Z31 R200 w/ CVs
jeffball610
Re: Adjustable Rear Spring Perch
Postby jeffball610 » 30 May 2017 17:17
This is what I'm currently looking at, but it states it's for 5" or 5.25" springs. It also says it has a 2.75" ID which would probably be too tight for a 3" ID spring.
http://www.speedwaymotors.com/AFCO-Adju ... 49203.html
1972 Datsun 510
Postby Three B's Racing » 31 May 2017 04:59
jeffball610 wrote:I'm having trouble finding any info on spring perches for the stock rear 510 location. I know someone has done it, but I can't even find good info on spring size. From what I can gather, the stock rear springs are about 4.25" OD and about 3" ID. The suspension kit I ordered 10 years ago from Top End Performance is no longer available, but works pretty well so far. I need to adjust the rear just a bit due to my Z31 spindle swap I did.
Drop the rear crossmember enough so the rear springs are loose at top then install a thick rubber spacer to fit your needed height adjustment with hole in the middle to clear the bodys spring stay. You'll need to slice from the hole to the outside diameter so you can slip it in without having to remove the spring. I did this with .25" hard rubber mat we use at work to raise the back almost a 1/2" easy.
deano510
Postby deano510 » 04 Sep 2017 11:47
We used something like this on our '98 One Lap of America 2dr. We used it to adjust the weight BTW the on track weight and over the road weight. Send me you email and I'll send you some pics of it. We used stock 510 rear springs and called them "weight jackers".
Please use my email below.
Dean
gzentas510@outlook.com
jeffball610
Postby jeffball610 » 05 Sep 2017 16:16
I found some weight jackers on Ermish Racing. The name is misleading, but seems to serve the purpose. I don't think it's cost effective to spend $400 on a system like this, so I've decided against it. Eventually I'll do coilovers, but I was hoping to find something more cost efficient for the time being.
1972 Datsun 510
fivetengarage
Postby fivetengarage » 06 Sep 2017 13:32
Check out the Design Products Racing setup.It's half the price of Ermish setup and says it will work with stock springs.
http://www.dpracing.co/datsun-510-rear-suspension-1
Postby Byron510 » 06 Sep 2017 21:50
The DP pn 234-1008 works well. It's a replica of what the original BRE cars used, and exactly the same design that's been in my 510 since 1971. At that price it's a pretty good buy. If you like your current spring rate, you may not even go to coil overs if you've got this set up. And if your auto crossing or tracking you can corner weight the car perfectly with these installed.
Danthewire
Postby Danthewire » 07 Sep 2017 15:27
Try some roundy round places like Howe, Port City , Lefthander etc.
Coleman Racing #20801 Weight Jack swivler $41.98
We used them when I raced late models.
Dan
Return to “Suspension”
Users browsing this forum: No registered users and 4 guests
