Wheel Speed sensor installation
VelvetHammer
Post by VelvetHammer » 31 May 2017 13:50
Anyone ever install wheel speed sensors on stock hubs?
The Motec system I'm installing has launch and traction control and would like to take advantage of it.
The data would also let me know when my LSD is locking up, or failing for that matter.
I figure I could make a two piece ring. The first half would be a mounting base for the second ring and get sandwiched under the bolt heads, the second ring (15 tooth? Researching...) would mount to the first ring and end up covering the bolt heads.
I should make this out of steel, right? I'm bit worried about the aluminum compressing under load, and those bolts are a pain to get to to have to check constantly.
The sensor would mount in a weld-in bung in the dust cover. Need to worry about flexion of the dust cover and air gap between sensor and toothed wheel.
Thoughts?
VelvetHammer
Re: Wheel Speed sensor installation
Post by VelvetHammer » 03 Jun 2017 13:57
I'm going to to take this as a "no"... I'll update as I engineer a solution.
Post by datzenmike » 03 Jun 2017 15:16
Why not on the half shafts? Or the stubs on the H-160.
VelvetHammer
Post by VelvetHammer » 03 Jun 2017 15:42
Hey Mike, there will have to be a wheel on the half shafts or diff as well. I could point a sensor at the bolt heads back there but I don't think that resolution is fine enough. I'm running a CV kit so for finer resolution I could mil/ press a series of magnets into the alum spacer, or fab a ferrous wheel and sandwich it in there. There isn't a ton of space for a toothed wheel to stick out without getting close to the trailing arm. Mounting a wheel at the diff end of the CV kit is a very interesting solution but I'd need to fly a pretty long, beefy, arm off a mounting bolt on the casing to hold the sensor steady without a variation in sensor/ tooth gap. Might be tough given road surfaces out here in LA.
The Motec system works by taking Ground Speed from the front wheels (if using two front sensors it picks the fastest speed of the two wheels), and compares that with the Driven Speed of the rear wheels (if using two rear sensors is averages the speed of the the two wheels). Engine management reduces power until the two speeds match (or hits target Slip table). (https://www.youtube.com/watch?v=sB8hEFPUWQg)
VelvetHammer
Post by VelvetHammer » 03 Jun 2017 16:00
For those interested here are some examples of the advantage of TC with higher horsepower applications:
https://www.youtube.com/watch?v=xe2ifNuiFOo
https://www.youtube.com/watch?v=BVEtZjeNacY
https://www.youtube.com/watch?v=6vZJt91vwDY
My goal is 375-400 RWHP with a supercharged L-Series motor, and for it to be usable, and safe.
510wizard
Post by 510wizard » 04 Jun 2017 08:06
The Suburu's have a bolt on speed ring on the hubs, aprox. 4" in diameter that problaly could modified to work. I'll see if have one and take a picture.
VelvetHammer
Post by VelvetHammer » 04 Jun 2017 18:56
510wizard wrote:The Suburu's have a bolt on speed ring on the hubs, aprox. 4" in diameter that problaly could modified to work. I'll see if have one and take a picture.
That would be most appreciated!
