Page 1 of 1
Suspension bodges
Posted: 11 Feb 2018 12:01
by KiKiIchiBan
Slotted top mounts for more camber:
Untitled by
Kieron Ash, on Flickr
Slotted LCA:
Untitled by
And more slots on the steering arm:
Untitled by
Assuming this isn't the norm, even for racing on the cheap and will all need to be replaces and fixed?
Re: Suspension bodges
Posted: 11 Feb 2018 19:22
by iceman510
The one on the steering arm looks like wear from a loose bolt. You can see material pushed up around the top of the hole. I can't see the point in slotting one side of a part that attaches to another at fixed points.
Posted: 11 Feb 2018 20:09
by icehouse
Shnikes! Don't the 240Z struts have a wider bolt pattern then the 510? Maybe someone was upgrading brakes???
Posted: 11 Feb 2018 20:36
by datzenmike
iceman510 wrote:The one on the steering arm looks like wear from a loose bolt. You can see material pushed up around the top of the hole. I can't see the point in slotting one side of a part that attaches to another at fixed points.
With the other bolt on it can't move in that direction. If both bolts were loose it could twist causing the holes to be worn to the sides.
Posted: 12 Feb 2018 12:20
by KiKiIchiBan
icehouse wrote:Shnikes! Don't the 240Z struts have a wider bolt pattern then the 510? Maybe someone was upgrading brakes???
Good point, the brakes are off an AE86 so maybe the struts are Toyota ones too
no marking on them, I’ll take some pictures and post them up to see if anyone can say yes they’re Datsun or not. No one over here who knows enough to listen to.
Thanks.
