Is there aftermarket calipers that use metric fasteners?
Re: Is there aftermarket calipers that use metric fasteners?
Post by RMS » 14 Mar 2018 23:32
I search your thread and no mention of 280 struts. are you still running stock brakes? if so why not stock 280 brakes and 13s ?
duke
Post by duke » 15 Mar 2018 13:24
RMS wrote:I search your thread and no mention of 280 struts. are you still running stock brakes? if so why not stock 280 brakes and 13s ?
The stock 280zx calipers are HEAVY. Going to an aluminum caliper can save a good amount of unsprung weight.
Post by RMS » 15 Mar 2018 15:30
it sure can but norm and I were comparing unsprung weight with my stock 280 brakes and 13in libras and federal uhp 595s I was something like 13lbs lighter than his setup Image
Post by funwithmonkeys » 15 Mar 2018 16:22
Those tires and wheels are 28.5lb. With the tires I have now the tire wheel combo is 30lb. From what I understand my 15x7 wheels are light at just over 14lb. Those calipers in the picture are right around 3lb before the pads.i think you are about 10lb lighter just in the wheel and tire.
Post by icehouse » 16 Mar 2018 12:30
Think I'm going to go with Z32 rears. Haven't decided on the fronts. I like the idea of brembo fronts. Anyone know a factory application that uses smallish 4 piston calipers. Smaller then the Z32 fronts.
Post by 510rob » 16 Mar 2018 20:43
superbikes? :P
StrutlessWonder
Post by StrutlessWonder » 16 Mar 2018 21:08
2nd gen RX7 turbo (FC) front brakes are 4 piston and finned aluminum
Kurt Hafer
Post by icehouse » 16 Mar 2018 23:31
StrutlessWonder wrote:2nd gen RX7 turbo (FC) front brakes are 4 piston and finned aluminum
I have a set of those in my shed!!! I saw them the other day. Thought they were steel (they looked rusty) I'm going to pull them out tomorrow. Thanks for the idea.
Post by icehouse » 16 Mar 2018 23:33
510rob wrote:superbikes? :P
Have to stick with solid rotors. I don't think the super bike calipers will open far enough.
Post by JordanTr » 17 Mar 2018 21:44
Some guys install spacers between the 2 halves of calipers to increase the allowable rotor thickness. Possible to do on the superbike calipers??
