Rear 5-lug Conversion
thehulk
Post by thehulk » 22 Mar 2018 12:10
I am looking into getting the front of my project 510 up to speed with Techno Toy's coilovers and wilwood brake upgrades up front. They also carry billet hubs that I would like to get to replace my front hubs that somebody welded the studs to. I would love to move to the 5-lug version of these hubs, mostly for wheel choice, but can't find and figure out what my options are on the rear. Any suggestions? I found a few things in the search, but they are likely outdated.
Thanks in advance.
Re: Rear 5-lug Conversion
Post by Byron510 » 22 Mar 2018 14:40
Why convert to 5 lug?
Plenty of new and vintage wheels out there with just about any offset you'd ever need for flared or unflared 510's.
Just curious as to what the motivation is? But when known, there are many ways to go about this depending on what you needs and desires are.
JordanTr
Post by JordanTr » 22 Mar 2018 17:49
5 lug is great!
I'm currently working on a rear CV axle conversion that would come complete with rear 5 lug axles. Once complete, this set will be up for sale. PM me if you would like more details.
toylet
Post by toylet » 23 Mar 2018 06:28
Mario from TSR will redrill/weld the rear hubs to 5 lug.
thehulk
Post by thehulk » 23 Mar 2018 15:38
Byron510 wrote:Why convert to 5 lug?
On a few searches for wheels, I've found a lot more options with the 5-lug wheels. That's the main reason. And I figured if I'm going to be upgrading the hell out of this car, may as well go all out, right?
thehulk
JordanTr wrote:5 lug is great!
If that's the route I end up taking, I'll definitely give you a shout. Thanks!
jeffball610
Post by jeffball610 » 14 Jun 2018 10:05
Again, why 5 lug? I did mine to get Z31 CV axles. I probably could have done the same or similar with Z31 4 lug options.
1972 Datsun 510
7-bolt 4G63T, EVO 9 pistons & rods, Garrett GT3076R, "Flipped" Stock Intake Manifold, Toyota R154, Z31 R200 w/ CVs
Post by Byron510 » 18 Jun 2018 12:18
Very interesting Jeff, thanks for sharing those photos.
Of course, I have to ask questions if you don't mind.
The 5 lug for your application is noted. And the conversion to using the Z31 5 lug hub giving you the brake caliper bracket and the CV joint is commendable - great work. Are all Z31 ZX's the four bolt flange shown? And were you able to shorten the existing CV shaft be having the splines recut? Or did you cut and reweld the shaft itself (possibly with a sleeve)?
I imagine that you must have jigged the arm for re-welding the hub in place to get proper alignment. If you were really good you could compensate for camber and toe at the same time! I'd love to hear your experiences.
JordanTr
Post by JordanTr » 19 Jun 2018 20:41
Only the turbos have 4 bolt flanges and ball in cage CVs. The NA ones in all years use tripod joints and a 3x2 bolted flange on different companion flanges.
