QA1 camaro rear shocks
guzzirik
Post by guzzirik » 24 Dec 2018 15:36
Iv'e seen camaro shocks referenced for the rear, particularly those from QA1. They have two versions from what I can tell in the non coil over variety..The first gen 703 and the second gen 704. Anyone have any experience with either of these?
Re: QA1 camaro rear shocks
Post by RMS » 24 Dec 2018 16:28
the q1a matched well to the 900+ lb specialty springs. I get a little bounce from the rubber upper bush and will probably swap over to poly
Post by funwithmonkeys » 24 Dec 2018 18:30
Yes I have the non coil over single adjustable. They work great with my 1100lb springs.
guzzirik
Post by guzzirik » 25 Dec 2018 19:49
What are the diameter and length of your springs and where can I get some? Thanks
Post by funwithmonkeys » 26 Dec 2018 08:42
Specialty engineering has a drop in spring that he sells. Stock diameter and shorter to lower the car. I have weight jackers so I have 2.5" diameter 6" long Eibachs.
