front suspension...whaaaaaaat!!!
guzzirik
Post by guzzirik » 31 Dec 2018 15:47
I removed the front stuff this weekend. the drivers side was the one i'd looked at before so when I removed the pass. side I wasn't ready. I'll post pics when i find my camera because Iphone pics are too large. The drivers side has a standard 510 caliper w/tapered pads, a 5.5" od x9" spring, a 9" rotor and a 27mm spindle {inner brg dia} The pass side has a 4.5" spring 15" inches long, a 9.75" rotor and a 32mm spindle. I am assuming the drivers side is relatively stock. the pass. side has a larger overall caliper with what looks like rear pads.
{I used to work on cars]
Both spring perches have what appear to be factory welds, the drivers being three .5" welds and the pass. side being fully machine welded. There is no evidence of either perch being moved. Does any of this sound remotely familiar..Again I apologize for not having photos yet...I am working on it as you read...Thanks...Rick
Re: front suspension...whaaaaaaat!!!
Post by Byron510 » 31 Dec 2018 18:08
Photos will tell us way more. Sounds like the pass side strut may have been 280ZX - photos will confirm both.
But the fact that both were different, and had different springs...bet that drove a bit strange!
Look forward to the update...the New Year can only bring better news :-)
yenpit
Post by yenpit » 02 Jan 2019 13:18
Is the passenger side rotor vented or solid like the drivers side? If vented, likely 280ZX, will have a more conventional caliper with single piston & slide bracket. If solid rotor, could be Z car (incorrect camber angle) or maybe S12 200SX (correct camber angle), both with conventional caliper with single piston & slide bracket.
If you pull a pad off passenger side, go to rockauto.com, look up the front pads for the above mentioned possibilities (or any other guesses!), go to "more info" on each listing, they should have a drawing/tracing of the pad to visually identify!
Good luck!
TJ
72 521 flat bed pick up
1965 Mustang GT Coupe
LOTS of 510 parts!
Post by datzenmike » 02 Jan 2019 18:25
Byron do you still have a link to that strut information post you made? I changed computers and lost it.
Post by Byron510 » 02 Jan 2019 23:54
I do Mike, but I don’t think I can post a .xlsx file on the realm since we changed servers.
I’ll see what I can do tomorrow.
guzzirik
Post by guzzirik » 03 Jan 2019 16:00
The rotor is solid and slightly larger than 510. I had 280ZX fronts on my '77 200SX race car and it's nothing like that..It's prob 200sx...Ive got a camera coming as I can't figure out Mac resizing from Iphone pics...Thanks
guzzirik
Post by guzzirik » 04 Jan 2019 18:29
I believe it's a 240-260-280 after studying photos of same...
Post by datzenmike » 04 Jan 2019 19:39
Byron510 wrote:
02 Jan 2019 23:54
Thank you
