Front short strut inserts whats available in 2019?
cartel
Re: Front short strut inserts whats available in 2019?
Post by cartel » 21 Jan 2019 15:45
well i ordered bilstein vw in the B8 and going to start with 250 lb front springs- they say the bilsteins will ship feb 8-- i guess i find out in 2 weeks if they do- if not then Koni race inserts will be ordered
rear going to start with 275 on qa1 coilovers for a baseline-
Mike Gibson
Post by Byron510 » 22 Jan 2019 00:11
I have used the VW Rabbit inserts and cut the struts down the match - it was low... Realy Low! I ended up making another set of struts using MR2 inserts.
But all’s not lost, just use a tube spacer at the bottom of the strut tube to bring them up - maybe 1-1.5” for a street car. There’s enough stroke in the VW insert.
My thoughts.
Post by icehouse » 22 Jan 2019 08:01
I just built some struts for my coupe with VW inserts on ZX struts. I cut 2" almost exactly out of the ZX struts. Your cut may very depending on the top nut.
cartel
Post by cartel » 22 Jan 2019 19:54
i already have a strut tube length ive used in the past- i will space the inserts to match-- i believe it was the shorter of the mr2 inserts - i checked some that are already welded together and the insert is below 13.5" - the vw and koni race are both shorter than this
Mike Gibson
guzzirik
Post by guzzirik » 19 Feb 2019 07:59
I have a set of Tokico BZ1085 fronts for an '86 MR2 that I apparently bought by mistake. They are the exact same length as the stock 280ZX inserts, 14 7/8 ". With uncut ZX strut housings, will this combo lower the car at all? Also Eibach 2 1/2 X 8 X 275#....
cartel
Post by cartel » 20 Feb 2019 08:24
275 lb springs will likely overpower a tokiko insert.. the insert has to have the appropriate valving to be able to control the spring pressure you are using. thats also really stiff for a street car imo.. the bilsteins which are currently STILL backordered come in B6 or b8 valving - if you want to use 275s i think you need the koni race or B8 inserts -
id start with 225 lb spring- with those-- or 200s.. all depends on how low for ride height. and if your under 150 hp then 175 lb-- and also factor in tire width and stickiness, and use. - theres many variables to consider for shock and spring--
Mike Gibson
Post by funwithmonkeys » 20 Feb 2019 19:49
If you need a set of eibach 200lb 8" springs let me know. I have a pair sitting in a box in my garage.
Post by RMS » 20 Feb 2019 22:02
member; one can only lower the stock bump stop by 1in before the sway bar collides with the tc rods.
guzzirik
Post by guzzirik » 21 Feb 2019 05:05
Well...Cartel...You just answered all of my unasked questions..I thought the springs might be a little much for the Tokico's, and my retinas. funwithmonkeys I believe you have a customer. I'll send you a pm. RMS, I read on a post where you can relocate the TC rod but can't remember where. Do you think the drop I'll get, about 2 inches?, will necessitate me doing that? Anybody need a pair of 275# Eibach's?
