Rear control arm clearance
Nustad 510
Post by Nustad 510 » 11 Mar 2019 20:34
Hi all,
Does anyone have pictures of their rear control arms after trimming the leading edge for wheel clearance.
Thanks, Shaun
Re: Rear control arm clearance
Post by bertvorgon » 12 Mar 2019 07:39
Morning Shaun,
Here is the best shot of what we did to mine, then also made the "doubler" plate welded across the top.
That amount of cut out let me run 13 x 8" zero offset rear wheels which I could just bolt right to the hub if needed to increase oversteer tendency. Really increased the stiffness of the control arm.
If you need more or closer pictures I could do that this coming weekend as my car is on jackstands right now and could pop a wheel off.
cut out on rear control arm. Double plate welded on top..JPG (180.29 KiB) Viewed 316 times
Nustad 510
Post by Nustad 510 » 12 Mar 2019 07:53
Thanks Keith,
Perfect. Picture says 1000 words. I only need to shave a bees d**k off mine to get the clearance. Im running 14 x 6.5 +25 rear wheels. BR Specials. A Watanabe look a like. 195/60/14 tyres. A poorly positioned wheel weight is all that's preventing the wheel turning freely, despite asking the tyre shop to place ALL weights inboard. If necessary, I can make and weld in the doubler plate at home. Out of interest, what sort of clearance are you running between the rear control arm and the rim?
Cheers, Shaun
Post by bertvorgon » 12 Mar 2019 08:13
I have tons as I am running a spacer, which I have always done to increase the rear track, with my 15" x 7"' zero offset VTO wheels.
Again, I can measure up on the weekend if you like. As I am flared I used to run a 1" rear spacer and at the moment I think I have a 1/2" or so on there, just like to have the car as wide as possible.
Post by JordanTr » 12 Mar 2019 09:23
With 16x8 +30 I just ground off the pinch weld on the control arm and then welded the material back together flush with the control arm.
Obviously the clearance gets better as the rim size goes up.
You don’t need much more clearance than a couple mm.
Nustad 510
Post by Nustad 510 » 12 Mar 2019 23:35
Thanks Jordan, I think that's what I need to do. Cheers, Shaun.
