280ZX brake failure warning light valve
guzzirik
Post by guzzirik » 08 Jun 2019 08:47
I was wondering if since I've changed over to 280ZX front brakes if I need to change the valve block on the fender well to one from same. Or are they the same? I haven't changed the master cylinder yet, waiting to see if the stock on will work OK, since PO installed a new one...If it is necessary to change it, recommendations?
Re: 280ZX brake failure warning light valve
Post by bertvorgon » 08 Jun 2019 10:01
You can leave it there..it IS just a warning switch for brake pressure loss on one end or the other. The 510 one works just fine with the master upgrade.
